TC 31 Brushless Conversion
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    #121
    As short as possible for your application.
    Douggie
    • dddmx3
      • Mar 2010
      • 244
      #122
      Ok Ill try
      After all is said and done, more is said than done.
      • dddmx3
        • Mar 2010
        • 244
        #123
        Sticked with the deans, I didnt like the idea of me accidently sparking the wires..
        Cut about 6.5in of wire off though. so its short
        First run tomorow... Should I make a video!?!?!?
        IM PUMPED!
        • dddmx3
          • Mar 2010
          • 244
          #124
          Thanks for your input guys(;
          I made a video.. Will be up soon...
          Used 40mm first then 42mm prop... 40 wasn't so good 42 was great!
          I'm going to order this, good or bad idea?!
          http://www.offshoreelectrics.com/pro...rod=octsb-x438
          • forescott
            Hopelessly Addicted to RC
            • 3009
            #125
            Why go to a smaller prop? If temps are good, I would step up to a x642 or maybe an m445.
            • dddmx3
              • Mar 2010
              • 244
              #126
              Problem is I'm bearly getting any water through my tubes
              • m4a1usr
                Fast Electric Addict
                • 2036
                #127
                If he has ran the boat using the 540 12XL can he speaks of on the first page then he knows that motor will not handle those props. A stock TC31 comes with a .32 nitro motor. Thats approx 3hp or more then 2000 watts. There is no 36mm 540xl can capable of 2000 watts continous. I dont care if its a Hacker, Nemesis, Fiegao, Keda,..... This has been entertaining to say the least.
                John
                Change is the one Constant
                • dddmx3
                  • Mar 2010
                  • 244
                  #128
                  Johns right. Plus I only tried the carbon filled props. I have to try my prather prop cause I just finished sharpening it.
                  • dddmx3
                    • Mar 2010
                    • 244
                    #129
                    Starting a 37" genesis build.
                    What should I go with? castle.. feigao..
                    • m4a1usr
                      • 2036
                      #130
                      Go with a pair of CC/Neu 1520 on 6S. Theres a bunch of guys who know that hull so they would know better. I dont own one so not sure if they would fit in the sponson tunnels. Could go with a single Leopard. A 5692 would be alittle overkill but a 5682 would be right in the W/HP ratio. Then theres the herd of outrunners too.
                      John
                      • forescott
                        • 3009
                        #131
                        If your sticking with the single motor, I would opt for the castle 1717.(1580kv) Its the same price as a feigao xl with waaay more power. If going the twin route, I would use the castle 1512's(1800kv). Both will run great on 4s, and short runs on 5s if it's still not fast enough. Either setup will smoke your old TC with the feigao xl!!
                        • forescott
                          • 3009
                          #132
                          I think 6s setups are a little too muck battery weight for that hull with twins. JMO.
                            • 9481
                            #133
                            the 1512's I think would work very well
                            • dddmx3
                              • Mar 2010
                              • 244
                              #134
                              Well I was thinking of going single..
                              So you said 1517? What type of esc?
                              Maybe this one??
                              Click here to view esc
                              • forescott
                                • 3009
                                #135
                                No, 1717. Go to castlecreations.com and click on the clearance sale section. They have 1717 motors for 70-bucks. The esc you pointed out will work great. I would keep the battery voltage to 5s max. That way you're not pushing the limits of the esc, and that motor has a ton of torque and will spin a pretty big prop. I would go with a 648 or a 452. I think it will be a reliable setup and you should see speeds in the 50's. You may get away with 6s on a smaller prop for some big speed, but my guess is you'll be happy with the performance on 5s. Even 4s for that matter.
