30" Scratch Built Cat
  • Norman2
    • Sep 2008
    • 354
    #316
    Originally posted by sailr View Post
    You want the NEU 1515/1Y!
    Hi Salir, Sorry to bother you but have some questions. I am going to order the Neu
    1515 1Y as you suggested. What ESC should I get that does not need too much
    programing?. I was using 2 x 2S1P 30C -8000 Mah SMC Lipos. I think the neu will
    need 6S, Using an Octura X640 Prop and have no issues with temperatures but
    maybe that will have to change. Like my dad said: If you can't beat them join them.
    Thanks for any help
    Norman
    34" Ekos Cat UL-1 Powered
    • tagasagwan
      Molino Boater!!!
      • 995
      #317
      Hi Guys!
      Where can I get plans for for a 32-35" catamaran? I have a 200A esc and 36-74 1900kv motor I want to use. Your inputs will be highly appreciated.
      Stephen "tagasagwan" Young
      Philippines
      My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
      MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.
      • rawsonreyes
        • 102
        #318
        ordering hardware for cat
        hi norman lomdel all, i will be completing the build next month will post some pics and thanks for the plans guys it the best build so far for me. norman post some vids with your races good luck with new setup.rreyes
        • jesflorida
          • Apr 2009
          • 81
          #319
          The build continues with blue foam added on sides, then covered with 1/16" balsa. The blue foam was sawed in half to reduce its thickness, mabe not necessary. To save time, the rear 2/3rd of sides was sheeted horizontially, the front third was sheeted vertically. The foam and balsa substantially stiffens the structure.
          The bottom sheeting from motor mounting frames to transom was reinforced with 6oz carbon fiber. The was the alternative to adding blue foam which would have interferred with needed space and made mounting the stuffing tube supports more difficult.
          At the transom and mounting frames for the outdrives/stingers, the previously carbon fiber matted wood was reinforced with 6oz carbon fiber 2x2 weave sandwiched with 1/64" birch ply. 1/4" bass wood was then added over the drilled holes to support the T nuts for the mounting bolts.
          Now ready to sheet all balsa with 1/64" plywood and construct deck. Will use blue foam on the deck also.
          • rawsonreyes
            • 102
            #320
            hi jes,your build is going very great keep it going hope to see some of these hulls winning races norman, has already got some wins. i am awaiting my electronics and hrdware to complete my hull,when finished i will post some pics of the build and some test vids.rreyes
            • norbique
              • 367
              #321
              Hi rawson,
              I read your post where you mentioned you want to make engine hatches on your boat. I've done just that. You can see my build here:
              http://www.rcuniverse.com/forum/m_88..._1/key_/tm.htm
              just go to page 3-4 if you want to see the hatches only.
              Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
              - Mark Twain
              • cyberhoops
                • Jan 2009
                • 74
                #322
                I finished my version of the 30" Cat today. The parts were cut by Alex Guzman, but from light plywood instead of balsa. I used pink foam in the front part of the sponsons and sheeted it with 1/32nd plywood. I still have a couple decals to add to the upper surface and clear coat it - but it is ready to run now.
                Like Norman's boat it will be powered by a UL-1 motor and ESC combo and racing in the P-Spec offshore class next season.
                Final weight: 4lbs 3oz with 4200mah batteries. It would be interesting to see how that compares to the balsa and epoxy versions of this boat.
                Now I just need a nice day for testing.
                Jim Stephens
                Puget Sound Fast Electric Boat Club
                • fmarcelo
                  • Mar 2010
                  • 12
                  #323
                  thank you
                  Originally posted by lomdel View Post
                  Here are a few pics of the cut-outs and a pre-glue temporary assembly. You will notice the two motor mount options that I can still decide on, either twin or single...
                  I am going on holiday for a few days so this project will be dormant for a while.
                  It is a nice project, i was looking at the set of plans that you sent me yesterday and was missing a lot of pieces, you thank you can get me the project for this one that you took a pic, thank you very much I will apriciate
                  • fmarcelo
                    • Mar 2010
                    • 12
                    #324
                    info need
                    The guy who did my laser-cutting is very keen to help anyone worldwide out with similiar jobs on balsa and plywood. PM me for the contact details.
                    That will be great to get the contact for this person I will like to have my set of plans done by him
                    • fmarcelo
                      • Mar 2010
                      • 12
                      #325
                      plans
                      Very nice set of plans where can i find those, please let me know
                      marcelo.implementos@hotmail.com
                      • Norman2
                        • Sep 2008
                        • 354
                        #326
                        Hi Marcelo, The plans I sent you were the ones I used to build my cats. It is only
                        for the frame and hatch. The covering sheets I made by drawing myself once I
                        completed frame. Let me see if I can find some more information.
                        Norman
                        • Norman2
                          • Sep 2008
                          • 354
                          #327
                          Hi Marcelo. Sent you page 2.
                          Norman
                          PS Look at the 34"scratch built cat thread on this forum. A lot of info
                          • rawsonreyes
                            • 102
                            #328
                            got drives
                            hi norman,got the drives hope to get two swordfish 120 from steven but just got a son and work is taking much time but keep the good work going.just need 2props 2esc's/new radio to put hull in the water for first run.keep you guys posted.rawson: ps money is slow right now.
                            • kennyrach
                              • 102
                              #329
                              Hi all i am back and in full steam
                              http://kennyrachtrains.com/
                              • boatbandit2
                                • Jun 2011
                                • 109
                                #330
                                Hi all i am building a 24" cat and was wondering what size brushless motor i should run will try and get some photos up this is my first full scartch built cat i have built deep vees
                                so i will need help to set this cat up
                                Thanks
                                Paul
