30" Scratch Built Cat
  • shockerman80
    • 212
    #271
    lomdel whos boat ever sheared the sponsons away from the hull??? I have never heard about this just curious thats all.
    • kennyrach
      • 102
      #272
      Hi rawsonreyes and all .As i can see your already to go ,The frame look sweet m8 will be one find looking boat when done .Also you can fiberglass some of the bullhead when the frame all build and Sq up before you sheet .here a picture of Zipp CrackerBoxes i just did for a friend of mine
      http://kennyrachtrains.com/
      • kennyrach
        • 102
        #273
        Hi all here the way i bend wood . first i draw and layout the line on paper the i put finish nail in 1/2 ply on the outside of line then i take a pvc pipe and cap one end then i put the wood into it then i use a 1300 watt monster steamer to steam the wood for 5Min then take it out and put it into the building jig and let dry over night or you can bend it on the boat and clamp it down it bean very easy .hope this help anyone ,here some picture of it
        • kennyrach
          • 102
          #274
          balsa wood sheared the sponsons away from the hull ? was it glue or nail together because i can,t not see how this can happen if it was glue and Epoxy together ,any picture of it ,just curious
          • kennyrach
            • 102
            #275
            Hi all i have a Lehner basic XL 3600 motor and it have an shaft dia of 3.175mm .So i am looking for a Coupler Flex Collet for this to hook to my 3/16" shaft adjustable stinger drive .?
            • rcboatfan
              • 253
              #276
              i want to do a twin build on lomdels hull but how will i ever get em motors in the hull?? the space looks quite small in there?
              SUPERVEE 27 37'' TWIN CAT
              • lomdel
                • 722
                #277
                The openings in the stringers where the motors would be installed through has been designed to allow for a 540 size motor with a cooling jacket. Before assembly make sure the motor screw holes is big enough and that the rear three bulkheads have been strengthened/reinforced. To tighten them, some kind of angled driver would help. I agree it is tight (I struggled my ass off to tighten the stingers screws on the inside , but did get it done eventually) but with the right tools it can be done. Some guys let their hatch stretch over the sponsons to work on the motor from above, I didn't for aesthetic reasons, and I know I am going to struggle a bit, but mine won't be for everyday running. It would be more of a working testament to my building abilities... I am still assembling hardware, haven't got the dough for electrics yet.
                • rcboatfan
                  • 253
                  #278
                  ok thanks lomdel! im going to get this build going soon!! and im quite excited! have you looked at hobby city electronics? you can get an xl size motor for 30$! and a 100 amp esc for 30 also! this is where im going to get my electronics hopefully
                  • lomdel
                    • 722
                    #279
                    Two 540 XL's would be overkill for this hull IMO. I intend to run 2 540 9L's with 2 120A ESC's.
                    • rcboatfan
                      • 253
                      #280
                      im going to make mine 36inch though
                      • rawsonreyes
                        • 102
                        #281
                        frp look on cat
                        hi lomdel kennyrach/normam, all this is some pics on the build it's lots of time but worth it hope you guys are doing some videos, to show set up and speeds. hope to see some soon.rreyes
                        • kennyrach
                          • 102
                          #282
                          wow m8 looking good and fiberglass side and bottom .Are the side made from sheet that you made yourself or got off the web
                          • rawsonreyes
                            • 102
                            #283
                            hi kennyrach, i did the frp skins for the hull the only wood parts is the cutouts.thinking of removable hatch covers for the motor sections just like fullsize hulls lots of work but very rewarding when finish. thanks for the support rreyer.
                            • kennyrach
                              • 102
                              #284
                              Hi rreyer me be at the Great South Bay Racing Inc., OPA Racing http://www.greatsouthbayracing.com/ this weekend it only 10min from my house .here the clip on it Promotional Commercial for Battle on the Bay:
                              • j.m.
                                • 847
                                #285
                                Why did you use chopped mat instead of woven fabric? Mat isn't NEARLY as strong.
