30" Scratch Built Cat
  • lomdel
    • 722
    #121
    Originally posted by Norman2 View Post
    ...What paint scheme are you
    planning? You are almost done with beatifull work. ...
    Thanks Norm. I got a set of 32" cat King of Shaves decals from Oliver at H&M and would like to utilise that if possible...
    • Norman2
      • Sep 2008
      • 354
      #122
      Lomodel, That is going to look awsome, awsome, awsome. Regards
      Norman
      34" Ekos Cat UL-1 Powered
      • Norman2
        • Sep 2008
        • 354
        #123
        30" scratch built cat
        Jesse and lomodel hello. Tested the cat again today to try and correct a small
        porpoising action when accelerating fast. Not at speed but in starting out from
        a dead stop. I installed some home made aluminum plates (photos attached)
        and adjusted them two degrees downward and to my surprise that not only fixed
        the problem but increased my top speed to 36.1 mph. Hope this will help if
        you encounter the same problem. Now to install a UL-1 motor and esc and lipos. Regards
        Norman
        • Jesse J
          scale FE enthusiast
          • 7818
          #124
          Interesting, I like! I may try that on my build as well, maybe with this size this starts to help lift the trnsom as well getting the whole boat out of the water more. I wish I could see how she looks at speed, these are beautiful hulls!
          Lomdel, hows progress? I am trying to get me a pair of those struts for my intruder build, Jeff says he can get me some I just hope he don't make me wait tooo long.
          "Look good doin' it"
          See the fleet
          • Norman2
            • Sep 2008
            • 354
            #125
            Hi Jesse, Have to say that your intruder hull is awsome. Where did you get it?
            Regards, Norman
            • lomdel
              • 722
              #126
              The pics in my last post is where I am still at. Not much time lately. I will continue soon... Can't find Silkspan or something similiar locally to fibreglass her and if I order it will take a while. No electronics yet, still saving up for that...
              • Jesse J
                scale FE enthusiast
                • 7818
                #127
                My buddy the Camel hooked me up. he had it in his garage along with a bunch of other untouched hulls and said he could part with it for a nominal price. I was very lucky on this one! I know you can get thm from Hydro & Marine if you do a search you find em pretty quick.
                See the fleet
                • lomdel
                  • 722
                  #128
                  Just for interest sake, a comparison between the still unfinished 30" cat of mine and the C5000
                  • shockerman80
                    • 212
                    #129
                    Boat looks good. The aft part of the c5000 / mystic is wayyyyyy different then the balsa cat your building.
                    • Norman2
                      • Sep 2008
                      • 354
                      #130
                      30"scratch built cat
                      Hi lomodel, I must admit that they are very similar. Shockerman did a good job
                      when he designed this cat. I am very happy with mine so I am going to install
                      a UL-1 power system. The boats look exactly the same. This is a surprise. Yours
                      is coming out super. I am jealous. Regards
                      Norman
                      • Norman2
                        • Sep 2008
                        • 354
                        #131
                        JesseJ, If I get 2S1P 20C 3000 MAH lipos will they work. What does the 1P mean. Thanks
                        Norman
                        • Norman2
                          • Sep 2008
                          • 354
                          #132
                          Hi Jesse and lomodel, Just completed my air scoops the way i like. Hope you like.
                          Regards Norman
                          • Jesse J
                            scale FE enthusiast
                            • 7818
                            #133
                            Hi Norman, nice scoops, I need me some too!
                            The P just means how many cells in parallel. if you have two 2S packs, and you run them in series, then you 4 cells and no parallel cells or 4S1P. If you use two 4S packs in parallel, thus doubling your capacity (3000mah to 6000mah) then you have 4 cells in parallel, or 4S2P.
                            I highly recommend going at least 4500 mah. I know I had the same reaction when I was first told this, but you will be glad later when you are still using your first packs. I have several sets of low mah packs that I just don't use anymore.
                            If you can do it, go for two packs of 4S and if you parallel them up you can go for say 4000 mah capacity. If you are only doing 2S packs in series, then please, do yourself a favor and get the 4900 mah packs I suggested in the first place. 2 reasons, better current flow to motor and longer run times. If you are installing the UL1 motor/esc then by all means, get high mah packs!!!
                            Good luck, do you like my new signature? saw it in a recent post and man I support it fully.
                            See the fleet
                            • Norman2
                              • Sep 2008
                              • 354
                              #134
                              JesseJ. will follow your advice and go 4500MAH. My God, what a fleet. If I had one like that
                              I would definitely be divorced. I only have 2 cars, 2 sailboats, and two Fast electircs boats
                              and she is now raising her eyebrows. Wait till the lipos and charger gets here. I wil have to
                              take her out to a big dinner. Regards
                              Norman
                              • Jesse J
                                scale FE enthusiast
                                • 7818
                                #135
                                You guys crack me up! I had to read to my wife, she commented, "at the very least [a big dinner]"
                                She is tolerant, and very understanding - doesn't hurt that she see how working in "my dominion" relaxes me.
                                See the fleet
