30" Scratch Built Cat
  • kennyrach
    • 102
    #286
    I use the chopped all the time for lay out .Here a little description of it ,#1
    product name:chopped strand mat
    description:chopped strand mat is made from fiberglass strands chopped to length and bonded together with powder binder or emulsion binder.
    application:chopped strand mat is used primarily for hand lay-up process, filament winding and press molding of FRP products such as laminates, boats, complete set of bathing equipment, automotive parts and cooling tower, etc.
    Properties:1.good wet out 2. easy to form 3.very high tensile strength, suitable for filament winding or continuous laminating.4.good resistance to watering and chemical agents in anti-corrosion applications. #2 And the Woven Roving is for large item here some info product name:Woven Roving
    description:woven roving is produced from roving especially designed for weaving.
    application:woven roving is used mainly in the manufacture of large structural objects such as boat-hulls, car bodies, swimming pools, and other FRP products. # 3 description:fiberglass mesh is a mesh fabric woven made from fiberglass roving, and then coated by alkaline resistant latex.
    application:fiberglass mesh is widely applied in wall reinforce, external wall heat preservation and roofing water release. It is also an ideal material in the building industry such as the reinforcing cement, marble and mosaic construction.
    Properties:1.high performance in chemical-corrosion resistance. 2.high strength 3.good agglutination capacity and fixation performance. So all 3 will do the same job fine
    http://kennyrachtrains.com/
    • rawsonreyes
      • 102
      #287
      brand new yellow mean machine
      hi kenny all, got a trade today mean machine for zenoah engine with speedmaster hardware post some pics tomorrow.thanks for the explanation to that guy about using mat compare to rovin. those vids looks great please pm me with some personal info about yourself.thanks rreyes
      • j.m.
        • 847
        #288
        Marketing anyone?
        • kennyrach
          • 102
          #289
          Hi all .I will have to stop building for 6-8 week I have an accident with my F150 truck pick up and my left hand is broken .So i be watching you all build for now
          • rawsonreyes
            • 102
            #290
            hope you get well soon
            hi kennerach .sorry to hear of that accident hhope you recover soon and get back in the game.rreyes
            • rawsonreyes
              • 102
              #291
              new pics 31 cat
              hi guys this is were i am at in this build epoxied the inside with west system epoxy going to start sealing main deck tomorrow with expanding foam for floatation spray can type.by september i will have all electronics and motors.have n't decided on type for motors but looking for 55/60 mph any one with tested setup for that speed send the info. this is for lomdel please let me know what setup you are using and speed eg drive types/ prop and prop rotation inside /out.thank rreyes.
              • kennyrach
                • 102
                #292
                Man WEST SYSTEM epoxy is a marine epoxy of the highest quality;what a way to go m8
                • lomdel
                  • 722
                  #293
                  Originally posted by rawsonreyes View Post
                  ...this is for lomdel please let me know what setup you are using and speed eg drive types/ prop and prop rotation inside /out.thank rreyes.
                  Rawson, I don't have a complete set-up yet. I will order 2x 540 9L motors and 2x 120A marine ESC's at a later stage when finances are better. Currently I have the Graupner rudder, 2x Etti 4mm stingers with .130 left- and right lay flex cables and Octura X442 inwards rotating right- and left props. This I will run off 3S lipo for each ESC. I didn't build this cat to be fast, but to prove to myself that I can build one from scratch. If it floats and reach 35+mph without flipping, I'll be more than happy...
                  As I mentioned earlier I have a rather big problem with my sponson's vertical alignment. Due to this, I will not try to push her too hard. I am considering completing this build, run her a couple of times, shelving her, buy a Agitator hull and transplant all the hardware and electronics.
                  • Norman2
                    • Sep 2008
                    • 354
                    #294
                    Hi Rawson,Lomodel,Kennyrach and Jesse J.
                    Our Club has created a Limited Spec Offshore class. Rules are 26-30" hull, SV27, BL26 or UL-1 Powerplants and ESC. 2S1Px2 Lipos.
                    Race will be this week-end and I will be racing the 30" Scratch built cat. I have installed the UL-1 Motor/ESC and will see how it
                    will come out. Was going to Race My Titan 29 but I replaced motor with an Ammo 36-50-2300 which they will not allow in the LSO Class.
                    Will let you know results. Regards
                    Norman
                    PS Kenny sorry about your accident. Get well soon
                    34" Ekos Cat UL-1 Powered
                    • kennyrach
                      • 102
                      #295
                      Thank Norman and good luck
                      • rawsonreyes
                        • 102
                        #296
                        hi guys kenny lomdel norman jessej, here are some pics of the build and mean machine hull. thanks for the info lomdel i have the same financial woes like yourself but it's only for a short time hang in there.
                        • Norman2
                          • Sep 2008
                          • 354
                          #297
                          30" Scrath Built Cat
                          Hi Rawson, Looking good. Your Scratch Built Cat is going to be much prettier
                          than the mean Machine. Regards
                          Norman
                          • Norman2
                            • Sep 2008
                            • 354
                            #298
                            Hi Rawson. I am attaching some photos of my cat to give you some incentive to
                            finish yours. It is Fast, Handles perfect, and it is pretty. You will be very happy
                            when you finish. Mine is a single UL-1 motor but my goal was 45MPH and I have
                            reached 46.2. Now to races on Saturday. Regards
                            Norman
                            • Jesse J
                              scale FE enthusiast
                              • 7818
                              #299
                              Rawson, you are so close!!! Norman that is great news! I really like your exhaust system, did you make it or order? Could you post some close ups of them please?
                              Good job on the rah rah for Rawson, you are gonna have a great cat - I agree much nicer than the MM. Keep it up!\
                              "Look good doin' it"
                              See the fleet
                              • Norman2
                                • Sep 2008
                                • 354
                                #300
                                Hi Jesse, I made the exhaust pipes from square basswood and brass tubing.
                                I guess I was trying to motivate rawson as I have not seen any cats completed
                                except yours. Regards
                                Norman
                                PS Did you finish the Intruder?
