30" Scratch Built Cat
  • kennyrach
    • 102
    #211
    Originally posted by rawsonreyes View Post
    hi kennyrach, thanks again for the laser cut guy, i got a reply and the price isl for the 40$ just awaiting on the payment info from him. soon i will be posting some pics.thanks again all the guys for the help.
    Thank for relay i am glad if work out for you .
    .This guy did 3 boat for me .So send some picture of the cut when you get it
    http://kennyrachtrains.com/
    • rawsonreyes
      • 102
      #212
      hi kennyrach, when i get the cut outs i'll let you know. soon as i get it i will start the build and post it.thanks again rreyes
      • kennyrach
        • 102
        #213
        HI Rayson sound like a plan here some picture of my boat i am building
        [ATTACH]14318[/ATTACH]
        [ATTACH]14319[/ATTACH]
        [ATTACH]14320[/ATTACH]
        [ATTACH]14321[/ATTACH]
        • rawsonreyes
          • 102
          #214
          Cut outs being shpipped
          hi kennyrach mr guzman is sending the kit next week hope to get then before i leave for work next thursday. soon the builds will start.
          • kennyrach
            • 102
            #215
            Rawsoneyes Your be happy with it m8
            • rawsonreyes
              • 102
              #216
              cutouts to be at home soon
              hi kennyrach i will be getting the kits about friday but will be starting the build next two weeks when i return from work.i will post some pics when i return.thanks again rreyes that's how i feel.
              • rawsonreyes
                • 102
                #217
                hi lomdel ,normam got kits today will be posting when i return home thanks guys.hope shockerman got the frp hulls ready. i am doing a single/twin until next 2wks.rreyes.thanks again kenny.
                • Norman2
                  • Sep 2008
                  • 354
                  #218
                  Hi Rawson, Glad to hear you got your frames and are ready for a build. Just some advice, make
                  sure you make this boat as strong as you can with braces in the frame. make sure before you
                  start sheeting to use a lot of fiberglass resin. Also once you have sheeted also use Fiberglass
                  resin to seal her. You will have an excellent boat. I am super happy with mine which is UL-1
                  powered. It rides super, handles excellent and hits 45.8 MPH on GPS. That is all I wanted.
                  Please let me know if you need any help. Regards
                  Norman
                  34" Ekos Cat UL-1 Powered
                  • lomdel
                    • 722
                    #219
                    Good luck with the build, Rawson!
                    Here is a couple of update pics on my build. After a LOT of resin, filler and a LOT of sanding and several layers of spray-on primer and several layers of white final coat, this is where she is at. It is not perfect, but the blemishes will be covered by some decals (). The blue of the King of Shaves colour scheme is next (if I can find the right shade of blue that is) and then a few clear coats to finish it of. I am still waiting for my SV27 cockpit to use on the deck-lid (ala Norman) and then that needs to be finished. I already have the KoS decals (a bit big but not too much).
                    Once the hull build is finished (hopefully soon) the cat will rest, 'till I have enough money to spend on the electrics...
                    • Norman2
                      • Sep 2008
                      • 354
                      #220
                      Hi Lomodel, She is looking fine. Mine also had some blemishes which I covered with graphics.
                      It will look good when you clear coat it. Regards
                      Norman
                      • jesflorida
                        • Apr 2009
                        • 81
                        #221
                        I am hooked. Can you sell a cut set of frame and skin wood? If so, what price?
                        Thanks,
                        jesflorida
                        • kennyrach
                          • 102
                          #222
                          Hi Rawson .here the Ebay item #310142265502 for the
                          EPOXY RESIN MARINE GRADE BOAT REPAIR FIBER GLASSING that i use all time ,you get 32oz for $33.00 .so how the kit so far .and sand all wood with 80 grit paper before building it save lot of time and bond better .Me i use 5min Epoxy on the boat and then seal all jointed with the MARINE GRADE EPOXY RESIN.so i will post some picture of my 1/4 scale Zipp cracker box than i am building now .
                          • kennyrach
                            • 102
                            #223
                            Hi jesflorida You can have this boat laser cut by Mr Guzman at just tell him Bob from Kennyrach send you It cost about $40.00 and up or you and you can get all the wood from here at National Balsa Co
                            • Jeff Wohlt
                              • 2740
                              #224
                              Here are the 3/16" struts. Two bearings in the strut. Nose built to your size...wire, cable or whatever. The nice thing is they fit pretty much any hydro or cat. They also come with brackets.
                              I love bearings in struts and for wire drives they are excellent.
                              Nose removed and bearing comes out to replace...simple but effective. This one has not had a polishing.
                              www.rcraceboat.com
                              jwohlt5362@yahoo.com
                              • bigpapa
                                • Apr 2009
                                • 2531
                                #225
                                hell looks what i need for my intruder jeff check my sv in this section
                                THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
                                CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
