30" Scratch Built Cat
  • lomdel
    • 722
    #181
    The charge is usually per minute not meter, because the intensity and speed of the laser cutter is set according to the thickness and material density being cut. That is why cutting a 1meter 3mm balsa is much cheaper than cutting a 1meter 4mm plywood, for example...
    • CornelP
      • 793
      #182
      Got it. My offer was for plywood 3 to 5mm. For Balsa 3-5 is 0.7.
      • crabstick
        • 955
        #183
        How many mw or watts is the laser?
        Matt.
        www.rcboats.co.nz
        • CornelP
          • 793
          #184
          If that was a question to me, it's easy... Have no idea... They cut max 8mm ply, 10mm balsa, 10mm clear acrylics. No forex or other foams (chlorine fumes...)
          • ice_spy
            • 136
            #185
            Im not a laser expert and far from it. The cutter is actually a friend! So i dont think he was ripping me off with the price, actually doing it maybe a little cheaper!. But yeah i totally agree.... for this much outlay, i would just prefer to go buy a head of the river cat. Save a lot of time and prob cost around the same. If you guys really want to know all the laser specs, i can ask.
            Shame as its very rewarding to float your own boat.
            • lomdel
              • 722
              #186
              Theres been some progress on my build. I'll post pics soon. I ordered a SV27 cockpit like Norman's and is currently busy with sanding down the primer coat after 3x coats of resin was applied. Tip: Let resin dry horisontally, NOT vertically!!
              • Norman2
                • Sep 2008
                • 354
                #187
                30" scratch built cat
                Hi Lomodel, I have a set of Proboat apache 24 cat twin canopies you can have
                in case you decide to go twin cockpit. Let me know if you want them and I can mail
                them to you. Regards Norman
                34" Ekos Cat UL-1 Powered
                • Norman2
                  • Sep 2008
                  • 354
                  #188
                  Lomodel here is a photo.
                  Norman
                  • lomdel
                    • 722
                    #189
                    Thanx Norm, but I want to go as scale as possible with this one. The SV27 cockpit should work just fine for now...
                    • Norman2
                      • Sep 2008
                      • 354
                      #190
                      30" Scratch Built Cat Or Mono
                      Hi, I have a hatch with twin cockpits from a ProBoat Apache 24 which could be
                      used for Cats or Monos. Please let me know if anyone can use them and I will
                      ship free. This would be easier than styrofoam. Attached Photo.
                      Norman
                      • j.m.
                        • 847
                        #191
                        You guys can also use airplane canopies.....
                        • kennyrach
                          • 102
                          #192
                          I taken one
                          Originally posted by lomdel View Post
                          I managed to redesign the plans to 810mm length with a 150mm wide tunnel and modified it so that brace F becomes a slightly tilted plywood twin motor mount. The plans are available as JPG, PDF or DXF for those who want it... That is a CAD rendering below, not the real thing yet.
                          The single drive version is also available in the same format.
                          Hi m8 i like one of these plan
                          http://kennyrachtrains.com/
                          • lomdel
                            • 722
                            #193
                            I just had a major set-back! The hull was out on the patio drying the primer coat in the glorious South African sun. I looked away for a couple of minutes and my 18 month old daughter got hold of it and slammed it nose first onto the floor!! Major damage to the right sponson nose section! I'll have to take everything off there and sheet it with a few layers of fibreglass probably. Another week down the drain... I know I promised pics soon but I'll take some when the damage has been fixed. Oh the joys of parenthood!
                            • kennyrach
                              • 102
                              #194
                              Sorry to hear that . I have my son damage one of my boat.but to me building and repair damage hull is what i like the most ,Also thank for plan. but it have no Units of Measure on it .
                              • j.m.
                                • 847
                                #195
                                The plans from Lomdel are in mm.
                                And that stinks... I was looking forward to seeing your hull for motivation to build mine.
