30" Scratch Built Cat
  • Jesse J
    scale FE enthusiast
    • 7818
    #61
    Lomdel, I fully understand how that stupid wood can get the best of ya. However, you must conquer this beast. You had such a great thing going, are you sure you can't salvage the framing? I thought you were on to something really good. what happened? Oh well, I know people who got so frustrated they started smashing and then gave the fireplace a nice snack! I am sure you'll be back, there ain't nuttin like seein the fruit of your heart and soul and CA encrusted fingers go skitterin across the pond!
    Kudos Norman! I am really psyched to see your creation make roost!
    "Look good doin' it"
    See the fleet
    • lomdel
      • 722
      #62
      Jesse. I am actually sitting at the PC tweaking the design as we speak. I am in negotiations with the laser cutting guy ( laser@mailbox.co.za ) to re-cut the frame out of 3mm Ply for me. I am also seriously considering shrinking the cat a bit to about 28". I will then try and run two 540 9L motors off my existing 3S lipos through X442 props. This is to keep costs down.
      The main problem I have with the sheeting is cutting the profile of the sponsons out of the balsa after glueing a piece of 1/32" balsa to the frame. Maybe I should test fit it, trace out the profile, cut, and THEN glue...
      I can speak of CA encrusted fingers! My wife hates it, LOL!
      • Jesse J
        scale FE enthusiast
        • 7818
        #63
        test fit, yep, thats what I do. I get a pretty close measurement (you are doing cross grain on the bottom and sides, right? parallel to the steps? good) and then fine tune the shape once I get the bottom and sides sheeted. It is the epitome of trial and error.
        Why shrink the size? I have a 27" version and it screams on one motor.
        ps get some sleeeeep, eh?
        See the fleet
        • Norman2
          • Sep 2008
          • 354
          #64
          30" scratch built cat
          Hi Jesse, I am in agreement with you and hope lomodel does not give up on his
          project. I was going to paint today but the sun is not cooperating, Still waiting for
          all parts from OSE and then wil post some photos. regards
          Norman
          34" Ekos Cat UL-1 Powered
          • Norman2
            • Sep 2008
            • 354
            #65
            Hi Jesse and lomodel. Was able to get some finishing done. Still waiting for my
            OSE stuff. Will continue later on servo. radio. and battery velcros. Regards
            Norman
            • lomdel
              • 722
              #66
              She is beautiful Norm!! Please post some pics of underside and back as well. What does she weigh as empty as that?
              I removed all the @#$%^ sheeting from my frame, cleaned her up, strengthened some crucial members and is now ready to re-sheet her. I will do the bottom of the sponsons and then apply a thinned (with what?) coat of resin to the entire frame and bottom before sheeting the rest. I am back on track and motivated...
              • Jesse J
                scale FE enthusiast
                • 7818
                #67
                Excellent Lomdel! Glad to hear it.
                I use regular rubbing alcohol - someone please correct me if there is something better.
                Norman, I am really curious to see how that inline strudder looks/performs. Got myself one for my 27" scratch built.
                See the fleet
                • Norman2
                  • Sep 2008
                  • 354
                  #68
                  Hi all. Jesse is correct. You can also use acetone to thin the resin. The hull weighs 15 oz. without
                  the hatch and canopy which I still have not received from tower. Will post some pictures this
                  afternoon. Regards
                  Norman
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    #69
                    Wow, I just notice your pic of the finished product, very nice job! Could you post some more angles of you masterwork? How did the bottom come out? I am sure slicker than snot on a glass doorknob. I want to see her rear end too, maybe once you get your strudder in. I forgot, what motor you gonna slap in there?
                    See the fleet
                    • Norman2
                      • Sep 2008
                      • 354
                      #70
                      30" scratch Built cat
                      Hi, attached photos of bottom and transom. Regards
                      Noman
                      • lomdel
                        • 722
                        #71
                        Norm, some members here on OSE recently expressed their concerns about balsa's structural integrity. Do you have confidence in your build's structural rigidity and strength?
                        If I have to sum up the proposed steps of strengthening and finishing the hull it would go like this, please comment and correct me if I'm wrong:
                        Strengthen framework with thinned resin mix before sheeting. After sheeting with 1mm Balsa (cross-grain where possible), apply (spray or brush?) several coats (3x enough?) of sandable polyurethane sealer sanding (grit?) between each. Then apply a thinned resin mix (brush?) to outside for strength and sand smooth. Then spray primer and sand. Then spray final coat and clear coat(?). I am new to automotive finishing and would appreciate some info on this...
                        • Simon.O.
                          • 1611
                          #72
                          I have a lot of confidence in Norm's build as I do in my own.
                          I'll be watching his and I am sure he will be watching my build and development.
                          If used in the correct way as far as grain direction, thickness, and design. I believe that balsa has a place in FE despite some views to the contrary.
                          I will agree with JT that weight is not an issue now that we have lipo and BL. I have a bit of ballast in one of my hydros on his recomendation to prove that.
                          I use balsa with wads of good varnish as it is a lot less expensive than precision ply. I do use hardwood in a lot of places that I believe need the bracing or outright strength (transom).
                          Keep it going Norm and Jesse. The balsa boats will survive, if we make them tough enough.
                          • Norman2
                            • Sep 2008
                            • 354
                            #73
                            Hi, If you build them right then no problem,
                            Norman
                            • lomdel
                              • 722
                              #74
                              Norman
                              I don't exactly know about the right way, but I am doing this one (more or less) my way.
                              I finished sheeting the sponson bottoms (with steps) and the sides tonight. She is beautiful!! I will take some pics tomorrow in sunlight.
                              Next I want to fibreglass/resin the interior completely for strength before I sheet the deck, bow and aft. BTW, I used 1mm balsa for the sheeting.
                              Be patient with my build, I have a baby and a 5 year old and a lot to do, so i burn the midnight oil on my projects...
                              • lomdel
                                • 722
                                #75
                                Here's a few pics of the sheeting up till now...
