Mhz mystic 114 build
  • BUMBLESPECIMOODA
    • Feb 2023
    • 257
    #226
    Hinged:
    • BUMBLESPECIMOODA
      • Feb 2023
      • 257
      #227
      Continued:
      • autolex
        • Sep 2021
        • 85
        #228
        Incredible detail! What a great build to watch!
        MHZ Mystic 84 (BUILD) | DYMotorshop 750mm Mono (BUILD) | BlackJack 24 of Theseus (54mph) | ProBoat JetJam (toy) (BUILD) | Noodle Recovery Scaffolding (6.6mph)
        • BUMBLESPECIMOODA
          • Feb 2023
          • 257
          #229
          Ruddering... Put the threaded inserts in.
          I had a satin clear on the rudder parts, but because the boat and the other bits are hi-gloss, they didn't look right. So, re-clearcoating all the rudder bits.
          Faux hydraulic lines on.
          • BUMBLESPECIMOODA
            • Feb 2023
            • 257
            #230
            Rudder done. The heatshrink hosing idea didn't work out as planned. Gonna hunt the web for wee silicone line.
            • vvviivvv
              • 1148
              #231
              Where did you get the foam that you've used for the hatch lip from?
              Looks good quality stuff,
              Uk SAW record holder
              • BUMBLESPECIMOODA
                • Feb 2023
                • 257
                #232
                My friend Jeff on Amazon. 1/8" or 3mm adheasive neoprene foam. I used the hatch for a template, and ran a new x-acto blade to cut to shape. Put a few drops of soap in a sink of water, peeled the backing off, wet it in the sink, mushed it on with a towel, starting at one edge, and pulling it to reach all the edges while squeegeeing with the towel. When stuck good, I releived the tension with some x-cuts in the middle, then run the knife along the inside of the hatch to trim. Comes out ok. Die-cut exactly would be awesome.
                  • 4338
                  #233
                  Using a full sheet is an interesting idea. I've just used adhesive neoprene tape and cut contours/seams in the four corners.
                  • BUMBLESPECIMOODA
                    • Feb 2023
                    • 257
                    #234
                    Electronics done. I wanted a clean, un-cluttered look. I'm happy.
                    Deck details done. Rails made from black stainless spokes. Was gonna add heli-hooks, but my hands need rest.
                      • 4338
                      #235
                      The black spokes were a great idea. What are the faux instillation grommets made from, just painted circles or epoxy build-up?
                      • BUMBLESPECIMOODA
                        • Feb 2023
                        • 257
                        #236
                        If you mean around of the handles? If so, it is the epoxy resin (blackend with graphite) that fillets arond the bottom. I add little drips with a pin around them, until the diameters look the same.
                        • BUMBLESPECIMOODA
                          • Feb 2023
                          • 257
                          #237
                          Drives & such:
                          • BUMBLESPECIMOODA
                            • Feb 2023
                            • 257
                            #238
                            Cowl floation. A little cleaner than pool-noodles.
                            Glue-down side.
                            Visible side.
                            • BUMBLESPECIMOODA
                              • Feb 2023
                              • 257
                              #239
                              Hatches / latches done:
                              Rather than try to make a wee gasket on the dech-side, it is far easier to put a whole chunk of neoprene, on the hatch under-side.
                              • BUMBLESPECIMOODA
                                • Feb 2023
                                • 257
                                #240
                                More:
