Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 fightercat daytona build - RcBoaters Forum
  • dude123
    • Jul 2014
    • 265
    #106
    Hey guys so i benched tested my boat again to make shure rverything was in working order and it seems that i am getting this grindong sound in my stuffing tube area but my bend is very subtle. Do i just need to add more grease, what do you guys think?
    Every one knows the best part about building a boat is SANDING!!!! Just kidding
      With all the noise from the motor, how can you be sure that it is a grinding sound? How smooth do you feel when you insert the cable into the collet? The friction should be a smooth yet constant one, your instinct would have told you if something is already wrong.
      Are you using a liner?
      How is the bushing and stub shaft? Any bindings there? May not be from the stuffing tube....
      • dude123
        • Jul 2014
        • 265
        #108
        Their is no binding and the bushings are good i would like to change them to some better ones later. Their is not binding but i mean it turns freely it might just be the sound that it makes. Ill get pics today and a video of the maiden voyage
          • TheShaddix
            • Sep 2013
            • 759
            #110
            The sound is normal if it's out of the water. All the boats i've heard sound like something is loose because there is no load on the prop and the sound resonates through the hull. If the cable spins smoothly when it's in but not connected to the collet, then it's all good. Use some oil in your stuffing tube too.
            • dude123
              • Jul 2014
              • 265
              #111
              Hey guys so i got my boat out today and all i can say is wow it was SICK!!! It was ripping probably in the mid 60's for the maiden, not to shabby id say!! I will yry and figure out how to post the video today!! When i hooked it up to the computer it logged the max amps as 135.6a which in my eyes isnt to bad for 6s and with no adjustments, now its time for the technique and skill of tunning hahah. In the mean while here are acouple glammer shots.DSC_0030.jpgDSC_0031.jpgDSC_0033.jpgDSC_0035.jpg
                Congrats! man!
                • dude123
                  • Jul 2014
                  • 265
                  #113
                  Thanks dude im really stoked on it i am hopping to break 80 soon
                  • dude123
                    • Jul 2014
                    • 265
                    #114
                    Do you guys know were to get the little piece of foam that goes between the two control boards for the castle hydras 200hv? Also ehat is the best way to waterproof it(corrosion x)? Thanks
                      I remember reading the bulletin board, give Castle Creations a call and see what they have to say. It may be as simple as using a double sided thick tape. ( 3M makes heavy duty red dbl. tape sold at Home Depot) .
                      As for CorrosionX, do you realize that they come in two different viscosity? The red can we use is the thin one, good for motor bearings, etc. There is a green label which is thicker and better for ''waterproofing" electronics. I would get that one if I were to coat my ESC, just saying.....
                      • dude123
                        • Jul 2014
                        • 265
                        #116
                        hey guys so i ran my boat again today wasn't able to get a video thought couldn't do both at once, but this run i wasn't happy with. For some reason when it is getting up on plane it real leans to the right and i have a offset rudder which i think is causing the problem. Also it was running really wet, it wouldn't leave the water, stuck to it really hard, i will adjust the strut angle up a little and go from their. Also i was looking at my graphs for the data logging but they are whacked out i think can anyone tell me if this is wrong cause i highly doubt i am getting 106,000 rpms haha. Any advice would be awesomeScreenshot 2015-02-04 17.40.59.jpg
                        • dude123
                          • Jul 2014
                          • 265
                          #117
                          sorry for the size guys i cant seem to figure out ow to get it bigger. the max amp is 164.3a and watt is 3612, average rpms were 34, 414. Any other info just ask and ill let you know
                            Did you move the strut from the first run? My guess is you either moved the strut down or used a different prop. This hull like the prop up high. That's why mine did 64.5mph and pulled 236 amps and only turned 31k rpm. The rudder IS NOT the cause of the problem. It's called torque roll. Caused by a narrow hull with too much prop or too much prop in the water.
                            • dude123
                              • Jul 2014
                              • 265
                              #119
                              Ok i was only pulling 34krpm i will get the strut higher
                              • dude123
                                • Jul 2014
                                • 265
                                #120
                                DSC_0037.jpg heres a pic of the inside, still trying to finesse it
