fightercat daytona build
  • dude123
    • Jul 2014
    • 265
    #61
    heres a pic of the little beast.
    Every one knows the best part about building a boat is SANDING!!!! Just kidding
      That looks familiar! Lol
      • dude123
        • Jul 2014
        • 265
        #63
        Haha i would say so haha i just ordered the motor mount for it, should be here pretty soon. I still need to find a esc though
          If worse comes to worse, you can run an older version ( v2) seaking 180. It will need to be modified to run it safely. I remove all wires and upgrade to 8ga, disable the bec and run an external, replace the caps with higher voltage ones and add 5 more to it. Then you can run it on 6s and 7s. I do not recommend tooling around the lake on 7s however. That needs to be reserved for speed runs. 6s make still be a little too fast to cruise around but it will do it. You could run it on 5s (3s pack on left, 2s pack on right...must be matching mah and c rating) and be easier to cruise around.
          • dude123
            • Jul 2014
            • 265
            #65
            ya i was thinking of just trying to find another swordfish 240 or something of the sort. I would rather put the extra $$$ right now and get it and have alot of wiggle room than end up getting the 180esc and then end up getting the swordfish 240 later down the road.
            • ls1fst98
              • 905
              #66
              but then you have an awesome t180 to use in another project!
              and from what i was told and have read, the genesis/daytona doesnt seem to do well over a 45mm prop. looking forward to seeing another one done!
              • dude123
                • Jul 2014
                • 265
                #67
                Wouldnt the 200a 6s-8s be a beetter esc? Ive heard alot of good things about the seaking 180 though.
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  #68
                  6s2p, 220a 6s SF, x645...................
                    M645 would be a better choice. They usually pull less amps and had more top end.
                    • dude123
                      • Jul 2014
                      • 265
                      #70
                      I remmeber you saying that
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        #71
                        You are correct sir..................every now and then i forget i'm dealing with a cat.
                        • dude123
                          • Jul 2014
                          • 265
                          #72
                          what kind of radio systems do you guys use?
                          • dude123
                            • Jul 2014
                            • 265
                            #73
                            Ok guys so i have hit a road block in my build right now!! So i am trying to put in a cf plate and it seems that the shape in the interior is different than the exterior shape. In the pic above the template on the right is the interior template and the one on the right is the exterior one. Is something wrong or am i just making the template wrong?
                            • Chris Nason
                              • Sep 2014
                              • 114
                              #74
                              On both my builds I thought I could do a plate in the transom but ended up just flooding the transom drilling my holes used longer bolts with washers and epoxied over the nuts with that thick of a mount the whole rear or the boat would have to be ripped off to cause failure
                              • dude123
                                • Jul 2014
                                • 265
                                #75
                                ok thanks so about how much epoxy did you put in it? I was thinking of about 35 grams but i feel like i will need alot more
