fightercat daytona build
  • Make-a-Wake
    FE Rules!
    • 6057
    Randy seems to think that diameter is good as well.
    • dude123
      • Jul 2014
      • 265
      Ya ill take that into consideration. Thanks
      Every one knows the best part about building a boat is SANDING!!!! Just kidding
      • RandyatBBY
        • 3943
        Ya I have done it in a Scat Cat 32. Started a smaller prop x452 then a X455 I had about 15 minutes run time in the fifties. We went on up to a X462 but the boat was too small for that high of speeds and the newbie driver I built it for. all on 4S.
        Randy
        BBY Racing
          That is a great 4S motor you can prop up to a X460 and still have long run time. You will be flying around 70tie with that setup.
          I'm sorry but I had to go back and edit my post. But... 60mm prop on a daytona? Ummm...no. lol
            That's the same hull as my rivercat I think. On 6s my rivercat has been 84.5mph and with a 45 mm prop. I believe in the opposite as you....small prop....high rpm.....handle better.....drive better.
              Here's an 83mph pass. 6s. Same motor. M645 prop. Batteries Not fully charged to their capacity.
              • dude123
                • Jul 2014
                • 265
                hey guys so this is my cf inlay its my first one so dont be to harsh on me haha!!!DSC_0010.jpg
                • JMSCARD
                  • Mar 2010
                  • 4174
                  when you prop up on these narrow hulls like that, you lots of handling issues. I prefer a smaller or medium size prop and a decent amount of rpm. i'm not scared of 40 to 45k rpm in what we are doing with the boat. Ive build a few for people like this and they work reliably.
                  Totally agree with this, I like rpm on all my smaller boats... Anytime you start putting on a bigger prop the prop starts torquing the back of the boat in bad ways... Small props allow the hull to do what it was designed to do for sure!
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    I am not disagreeing with you completely, i was looking at some middle ground, in fact you can see in my speed calc post i used an x448 as the example..........your 645 is great as well, maybe a 548 etc..............
                      No problemo! I just have done enough experimenting with this particular setup in narrow hulls to know what way we need to go. Big prop makes these things roll over and/or prop walk pretty bad
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        Yep, the Genesis hull is the worst by far................thin sucker that it is! Anything over a 42mm makes it wanna flip on throttle input
                        • dude123
                          • Jul 2014
                          • 265
                          So my inlay seems to be dry enought at the moment so i think i will take the next step in reinforcing it. I plan on putting 35 grams of epoxy in each tip, and 36 grams in the transom. I heard of people chopping up some carbon fiber and putting it in their epoxy is their any specific way in doing so.
                            Wear a mask when doing this. Take some scissors and cut the edges of some carbon cloth into short carbon hairs. You don't need alot, but a decent amount. Do this over a sheet of paper. Then brush into your epoxy that's mixed and ready to go. Wear gloves and a mask or respirator. You don't want to breathe the hairs in, they float in the air easily.
                            • dude123
                              • Jul 2014
                              • 265
                              Ok thanks and safety first haha
                              • dude123
                                • Jul 2014
                                • 265
                                Forgot to post this but i just recieved the drive line and rudderDSC_0014.jpg
