fightercat daytona build
  • dude123
    • Jul 2014
    • 265
    #121
    Hey guys so i was wondering whats the best way to deal with my problem at hand. I have used two different colors of jb weld on my motor and servo mount and i would like to make them both the same color. Would i sand it down alittle then pit another layer of jb over it or should i just deal woth it because i could just make it worse?
    Every one knows the best part about building a boat is SANDING!!!! Just kidding
    • TheShaddix
      • Sep 2013
      • 759
      #122
      Sand it down a bit, then use some black epoxy to cover it both.
      • JMSCARD
        • Mar 2010
        • 4174
        #123
        What about just use a black sharpie and put on a few coats... Wide tip to keep the coats even? Just a guess but that's what I'd try first lol
        • dude123
          • Jul 2014
          • 265
          #124
          Ya ill try the sharpy first it doesnt hurt to try
          • monojeff
            • Nov 2010
            • 2728
            #125
            Sharply might work but a paint pen will work better!
            Paint pens are great for things like this.
            Sharps tends to want to erase itself on some things with multiple coats.
            See if you can find a black paint pen at michaels or walmart in the craft section.
            Make sure it's the wide tip.
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
            • TheShaddix
              • Sep 2013
              • 759
              #126
              A sharpie will leave a bunch of strokes and will smear on itself as you apply it. So will a pen. It's not a bad solution when you have a small chip to cover. Besides, it'll wipe clean off the second you need to clean your boat with some alcohol when it gets greasy. Just get black dye on ebay and mix that into your epoxy (a drop or two) and create new fillets and try to remove as much of the old ones as you can. Just a suggestion, this is what I would do.
              • Fella1340
                • May 2013
                • 1025
                #127
                Just caught up with this build, nice job man! You must be very pleased with the outcome
                • dude123
                  • Jul 2014
                  • 265
                  #128
                  ya im pretty happy woth it thanks, i still need to work on the interior woth the arangment of the wires but other than that i really like it!!
                  • dude123
                    • Jul 2014
                    • 265
                    #129
                    If you guys have any suggestions on things to do on the inside that would make it look clean im open for suggestions!! Thanks you everyone for all of the help
                      Mix up a bunch of graphite powder in jb weld. Tape it off again of course and scuff it up. Make sure you warm the jb weld up so it'll flow. Heat gun works well.
                      • dude123
                        • Jul 2014
                        • 265
                        #131
                        On thanks i read that in your daytona forum i believe i think i will sand it down alittle if i do that so its not so bulky
                          Travis, where do you get the graphite powder?
                            Originally posted by dude123 View Post
                            [ATTACH=CONFIG]127675[/ATTACH] heres a pic of the inside, still trying to finesse it
                            I like to see the wires, i know the rage is to hide everything, just like a modern car, you open the hood, you see NOTHING!
                            I am old school, I like to see the spark plug wires and the belts , so I think if you smooth out the JB, it will look really cool, not that it doesn't already look pretty cool!
                            • dude123
                              • Jul 2014
                              • 265
                              #134
                              I got mine from my local ace hardware for some reason it was in the auto aile. I like how it turned out when i used it
                                You mean graphite powder?
                                OK, Got it, it is graphite powder used for dry lubrication.
