DF Sniper 45
  • Make-a-Wake
    FE Rules!
    • 6057
    Doin' a great job Kong!
    • RCKong
      • Sep 2009
      • 1680
      Thanks. this thing will be built like a tank when I get done. I don't want to have this boat fold up on me at speed.
      • bill34207
        • Dec 2009
        • 2617
        M-a-W knows all about having one fold up at speed.
        My YouTube Vids
        • RCKong
          • Sep 2009
          • 1680
          I looked around here and actually found a piece of 3/8 stainless tube.
          I'm guessing it's stainless, I've had it for years now and it has not rusted... It will still take a brass liner, I wont use teflon in it.
          • RCKong
            • Sep 2009
            • 1680
            Bill, do you run 2p battery setups in your boat ?
            • bill34207
              • Dec 2009
              • 2617
              Yeppers. 9s 2p most of the time. It's easier to drive than 10s 2p.
              My YouTube Vids
              • RCKong
                • Sep 2009
                • 1680
                Thats what I thought, I'm playing around with laying the boat out, and I'm trying to avoid putting packs outside the rails
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  Unfortunately yes..................thanks
                    Originally posted by make-a-wake View Post
                    unfortunately yes..................thanks
                    ouch!!
                    • Punisher 67
                      Ignore list member #67
                      • 1616
                      [ATTACH=CONFIG]69969[/ATTACH]
                      Why don't you mount the esc on top of the motor....?
                      • RCKong
                        • Sep 2009
                        • 1680
                        I could, alot of folks do. I just never have done it that way. If I'm not going to put batteries outside the rails, the speedy can go there without having to fab a mount for it. Another way I look at it too is I keep the motor and ESC separated for better heat dissipation. Most electronic devices are engineered to keep heat generating components apart from each other.
                        Just sayin...
                        • RCKong
                          • Sep 2009
                          • 1680
                          I was able to spend some time working on this today.
                          With two sided tape you can "stick" all your hardware in place on the transom and check your configuration before you drill. I've done this for a while now and I saw Bill post using it also. Very handy...
                          I masked off the transom and layed it out, then traced around the hardware. I use the taped hardware itself for a "drill guide" This works well, and all you bolts fit when your done. Every time I drill a hole I put a bolt in to hold the piece of hardware in place, and drill the next hole.
                          In a boat with rails you want to make sure your bolts miss the rails. I try to lineup the rudder extension with the rail inside for added strength. I also was trying to keep the rudder push rod straight, and run it close to the rail to give battery clearance.
                          So far so good.
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            Great job......................looks almost identical to the rear of my Yellow 47"
                            BTW, i see you got the ol' classic 'orange millenium falcon with the rebel flag' avatar
                            • bill34207
                              • Dec 2009
                              • 2617
                              Looking good so far.
                              My YouTube Vids
                              • RCKong
                                • Sep 2009
                                • 1680
                                Thanks guys !
