These hulls totally take the speed. We were heat racing in the low mid 50s with these hulls on 2s2p as N2 monos. Only issue is the really rough stuff. You should have no problem running your setup and if you run it 4s1p you will essentially have the same weight as a hott N2 setup (1515 0.5y) running less amps (presumably ... unless you wanna go CrAzY)
As a side note ... the 1515 1Y in the boat would be really great. That's a nice motor in a small boat. Really easy on the gear and you can tune it up to get some great speeds. I have had one in a 24" viper and my 29" Seaducer.
