Help me build Delta Force 26 Overpowered
  • dana
    • Mar 2010
    • 3660
    #106
    Oh yeah, and it's not 5/8, it's 19/32.... Which is close enough I guess lol
    • dana
      • Mar 2010
      • 3660
      #107
      In ready to paint this sucker... Who's got some ideas?
      • Rich
        • 581
        #108
        What about something simple like this:
        • Drax21
          • Jul 2011
          • 1077
          #109
          • dana
            • Mar 2010
            • 3660
            #110
            so ive picked a couple of colors… and im thinkin about making a small intake above the windshield on top.ya know, just for looks…. whats a good simple way to do this? i was thinking solid wood and epoxy… lmk thanks
            • dana
              • Mar 2010
              • 3660
              #111
              ok guys, i finally got around to paint today… thanks for the ideas but i went with silver/blue. still gotta do the windshield. heres a couple of pics =) IMG_1806.jpgIMG_1807.jpgIMG_1808.jpgIMG_1809.jpgIMG_1812.jpg
              • millzee
                Ozzie Bloke
                • Nov 2010
                • 1097
                #112
                love the paint scheme, looks great
                "Gimmy Toyz for FUN"
                • dana
                  • Mar 2010
                  • 3660
                  #113
                  Thanks buddy \m/
                  • dana
                    • Mar 2010
                    • 3660
                    #114
                    i was able to get out and make a couple of runs thanks to the nice weather. the boat was a little bouncy and leveled out at higher speed. i know i have a long way to go here because, full throttle feels a little unstable. the boat is very fast. ive tried an x440/3 and m440. i do not like the m440 at all and the 440/3 does a nice job. ill try to get some video soon. i am a little lost on this one… i have used the trim tabs so far to adjust it, which i know is more of a band aid, im just not sure what i need to do here. i tried adjusting the strut angle a couple of times and neutral seems to work best…. anyways ill do some more testing and post some pics later. i do have odd placement of things in the hull compared to what ive done before on other boats… well see. more testing
                    • steveo
                      • 1595
                      #115
                      all hulls are not made the same one might be able to not use trim tabs of identical setup hull and some will,
                      • dana
                        • Mar 2010
                        • 3660
                        #116
                        so i got out again today with it. i tried once again to run with the packs all the way back (pic.1), and it ran like crap, so i tried lifting the turn fins out of the water just to see what happened. it was much worse, so i put them straight down, and that actually helped. finally i decided to bring it back in and move batteries up next to the motor (pic.2) and tried that. whoa! what a difference! unfortunately by then my packs were done so i only got about 30 seconds, but it was much better. so more testing i guess…. ill leave the batteries up front more and try more adjustments n the rear to dial it in IMG_1879.jpgIMG_1891.jpgIMG_1883.jpgIMG_1899.jpg
                        • dana
                          • Mar 2010
                          • 3660
                          #117
                          i ran some more this morning. took a nose dive and went under, came up with a nice chip in the new paint on the nose… crap lol
                          its was a bit choppy and it handled it decently, getting better with the setup but i did run into a problem and lost a prop.
                          when i got to taking stuff apart, i noticed the back of the strut looked like the drive dog had chewed into it a bit, and i left a decent gap. the speedmaster bushing was stuck in the strut. im pretty sure the drivedog chewed the strut and bushing together so they stuck. a few taps with a hammer and it came loose.
                          then i got the teflon out and it was all kinds of warped, and finally the cable which broke in the middle.
                          i had left a large gap of almost 2" in the wet well of just teflon between the brass tube and strut.
                          My guess? the gap was too large, causing the cable to warp and pull the drivedog into the strut and seize the bearing until the cable snapped.
                          so i put a much longer brass tube in the strut so it spans 90% of the gap. this should be better. kinda bummed i lost an x440/3 prop tho (
