Help me build Delta Force 26 Overpowered
  • dana
    • Mar 2010
    • 3660
    How is a flooded stuffing tube generally done? I get the basic idea, but is there any info on this?
    • LarrysDrifter
      Big Booty Daddy
      • 3416
      Ive been wanting to use a strut with a flooded tube. Never did it before, so I think itll be a good experience. If it were mine, id use a strut.
      • LarrysDrifter
        Big Booty Daddy
        • 3416
        Look up Racemechanics big Sniper build thread. Shows it in there.
        • pyroM!KE
          • 379
          Originally posted by dana View Post
          I see what you mean mike, but consider the fact that this thing is gonna have some serious power. Maybe more adjustability is not a bad idea. We'll see, I'm still shopping around to see what's out there.
          I stuffed a 4082 in a 33" on 6s ran in parallel(its a freaking powerhouse)..Thats not much more of a difference(power to weight ratio speaking)..But the flooded stuffing tube would be pretty cool to try..The only thing I dont like about a flooded tube is something getting knocked loose and causing leaks..Believe me..At the speeds your gonna be at, over strengthening everything is a good idea..Again there are many many different ways to tune one in every aspect..
          • CHUD
            • 554
            I'm watchin thisgood luck dana
            • 6BOOST
              • Sep 2011
              • 286
              I look forward to seeing your results Dana, I'll be stuffing a NEU 1515 in one in the next 2 weeks=)
              6BOOST
              6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
              • Make-a-Wake
                FE Rules!
                • 6057
                also im thinking about battery configuations. i could go 4s1p with one 4s pack up front or two 2s packs on either side of the motor, OR, one 4s pack and two 2s packs in series then parallel for 4s2p. confused… im thinking two 2s packs, and buying hyperion packs to run it. that motor, on my cheapo sky lipos when i was running 4s1p, were getting real hot…. decisions decisions...
                I've been eyeing these packs............made for heli's, 8c charge rate............65c continuous. Only 80 bucks for 4s, you could maybe go 4s2p with two 4000 packs(they look long and thin)..............i need to find some reviews on these batts.
                  • 9481
                  I'm gonig to tag along on this one..
                  I want to build a killer P-Mono using my Medusa 3670 2300kv motor
                  • dana
                    • Mar 2010
                    • 3660
                    thanks for all the positive input guys…. keep it coming. nice to see im not the only one doing something like this )
                      As in Medusa Research?Just curious and an excuse to tag along.
                        • 9481
                        yes sir.
                        • keithbradley
                          • 3671
                          Dana have you considered smaller 4s packs...something like 3000mah? You might be able to run 4s2p that way, and those packs would most likely have a more favorable configuration in your boat that running 5-6000mah 2s packs. As far as sky lipos, I was pretty impressed with them. I've had plenty of high dollar lipos, but the cheap sky lipos I had did everything I asked them to. I'm not saying they're exactly the same but I wouldn't expect a huge difference unless there was something wrong with your skys.
                          I don't really think the 2200kv 4074 is overkill for this boat. I would go as far as to say it would be (to many of us) the natural choice. I ran one in a SV27 and it was a bit much, but in the DF 26" it should run well. I think you will end up with trim tabs, though as some said you can always test without if you want.
                          www.keithbradleyboats.com
                            yes sir.
                            I've got a few of their BEC's.I'm told it's good stuff.Quality
                            BTW I have Thunder Power and Skylipo and also have no Qaums with getting other sky's.
                            • dana
                              • Mar 2010
                              • 3660
                              I like my sky lipos, but I know there are better out there. Keith, I hadn't thought of that but that's a good idea. I want to run 2p
                              • pyroM!KE
                                • 379
                                That is how I was able to run 6s2p in my CS..They were 3000mah in parallel for 6000 total..The 6s packs were the same weight as 3s2p 5000mah ran in series..
