**Guys** help me build a boat DF Cyber Storm 33
  • pyroM!KE
    • Jan 2011
    • 379
    #76
    Heres a phone vid..Im getting closer to being done tuning her..Fun Fun Fun!!
    • Drax21
      • Jul 2011
      • 1077
      #77
      That vid is going in my favorites!!!
      • pyroM!KE
        • Jan 2011
        • 379
        #78
        LOL! Thanks bro! Im just glad all the hard work is paying off now...
        • Drax21
          • Jul 2011
          • 1077
          #79
          What stinger angle are you running at?
          • pyroM!KE
            • Jan 2011
            • 379
            #80
            Negative 1 degree is about where my sweet spot is..
            • Drax21
              • Jul 2011
              • 1077
              #81
              Thanks, Mine looks a bit too much of an angle atm. Your COG is about the same as mine so stinger angles should work about the same. The shim is a bit harder to place behind the Fuller's stinger. Have you ran yours since you upped to 0.25"?
              • pyroM!KE
                • Jan 2011
                • 379
                #82
                Yeah..The 25 is probably where Ill keep it at..It still goes to the right a bit but its barely noticeable..I may try a .030 if I get bored one day..Is yours running to wet or to dry?
                • Drax21
                  • Jul 2011
                  • 1077
                  #83
                  First run was too dry so I dropped the stinger a few degrees but now think it may be too much.
                  Back up 2 degrees should do it.
                  • pyroM!KE
                    • Jan 2011
                    • 379
                    #84
                    If your running dry your gonna want to go positive angle..Positive will push the transom down in the water..You can also loosen the rudder and angle the bottom leading edge towards the transom..That will also help pull the transom down..
                    • Drax21
                      • Jul 2011
                      • 1077
                      #85
                      Thanks Mike. Got some kitchen stuff arriving in the morn. Hoping the weather is gonna be nice for the afternoon to go Lake. Gonna run a mix of batts in this boat, see which performs best. Will get a few videos if all goes to plan
                        • 9481
                        #86
                        I hear these are awesome P-Mono hulls!
                        • pyroM!KE
                          • Jan 2011
                          • 379
                          #87
                          I dont know..Ive never seen anything else run other than a MG..But i know Mine hauls major ass! and the handling is just simply amazing!
                          • Drax21
                            • Jul 2011
                            • 1077
                            #88
                            Hi again Mike. So by positive angle you mean stinger upwards? Ran it again today motor fully revving out. No ABS but prop kept slapping the surface. Its either a stinger or a weight problem. Stinger being easier to sort out than weight.
                            • pyroM!KE
                              • Jan 2011
                              • 379
                              #89
                              yes..Stinger up is positive..When you say the prop is slapping the water, do you mean its porpoising?
                              • Drax21
                                • Jul 2011
                                • 1077
                                #90
                                OK Mike, I think I got it. Have put the stinger up a couple of degrees. This forces the transom down, keeps prop is water correct? At the moment as soon as I hit around 32MPH the transom comes too far out the water and I can hear the prop slapping the surface. Didn't get much time today with the boat but I did run it and got same speeds as last time because I did not alter the stinger before leaving.
                                I was thinking the more I moved the stinger down the farther down it would be in the water(stupid moment) The boat isn't porpoising in the water, just rising out of it because of my stupidity.
                                My Pursuit was heavier at the back thus meaning my stinger angle could be parallel but my Cyber Storm is lighter meaning a upward movement of stinger is needed. I understand it now. Hoping no more angle than what I have give it is needed.
                                Have just got a Hyperion brand new off ebay for 4s 4200 45-90c!! saved loads cost me £45 or $70 in your money. Will let you know how the stinger thing works out. Hope to see some rooster tail next time Thanks Tim
