Heres a phone vid..Im getting closer to being done tuning her..Fun Fun Fun!!
**Guys** help me build a boat DF Cyber Storm 33
Thanks, Mine looks a bit too much of an angle atm. Your COG is about the same as mine so stinger angles should work about the same. The shim is a bit harder to place behind the Fuller's stinger. Have you ran yours since you upped to 0.25"?Originally posted by pyroM!KE View PostNegative 1 degree is about where my sweet spot is..Everything that has a beginning, has an End
First run was too dry so I dropped the stinger a few degrees but now think it may be too much.Originally posted by pyroM!KE View PostYeah..The 25 is probably where Ill keep it at..It still goes to the right a bit but its barely noticeable..I may try a .030 if I get bored one day..Is yours running to wet or to dry?
Back up 2 degrees should do it.Everything that has a beginning, has an End
Thanks Mike. Got some kitchen stuff arriving in the morn. Hoping the weather is gonna be nice for the afternoon to go Lake. Gonna run a mix of batts in this boat, see which performs best. Will get a few videos if all goes to planOriginally posted by pyroM!KE View PostIf your running dry your gonna want to go positive angle..Positive will push the transom down in the water..You can also loosen the rudder and angle the bottom leading edge towards the transom..That will also help pull the transom down..
I hear these are awesome P-Mono hulls!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Hi again Mike. So by positive angle you mean stinger upwards? Ran it again today motor fully revving out. No ABS but prop kept slapping the surface. Its either a stinger or a weight problem. Stinger being easier to sort out than weight.Everything that has a beginning, has an End
yes..Stinger up is positive..When you say the prop is slapping the water, do you mean its porpoising?Originally posted by Drax21 View PostHi again Mike. So by positive angle you mean stinger upwards? Ran it again today motor fully revving out. No ABS but prop kept slapping the surface. Its either a stinger or a weight problem. Stinger being easier to sort out than weight.
OK Mike, I think I got it. Have put the stinger up a couple of degrees. This forces the transom down, keeps prop is water correct? At the moment as soon as I hit around 32MPH the transom comes too far out the water and I can hear the prop slapping the surface. Didn't get much time today with the boat but I did run it and got same speeds as last time because I did not alter the stinger before leaving.Originally posted by pyroM!KE View Postyes..Stinger up is positive..When you say the prop is slapping the water, do you mean its porpoising?
I was thinking the more I moved the stinger down the farther down it would be in the water(stupid moment) The boat isn't porpoising in the water, just rising out of it because of my stupidity
My Pursuit was heavier at the back thus meaning my stinger angle could be parallel but my Cyber Storm is lighter meaning a upward movement of stinger is needed. I understand it now
. Hoping no more angle than what I have give it is needed.
Have just got a Hyperion brand new off ebay for 4s 4200 45-90c!! saved loads cost me £45 or $70 in your money. Will let you know how the stinger thing works out. Hope to see some rooster tail next time Thanks TimEverything that has a beginning, has an End
