**Guys** help me build a boat DF Cyber Storm 33
  • pyroM!KE
    • 379
    #61
    Just figured I'd update the pics.. Im not finished with the graphics yet but here she is right now..
      sweeet!
      • Drax21
        • Jul 2011
        • 1077
        #63
        Its looking real nice. The hatch does seem a bit flimsy on the Cyber storm. Think I'm gonna layer mine with silicon. Will make it a bit stronger and waterproof if it does crack. I need to get a few more graphics on my boat. So far just got the Eagle on the front although it does look pretty good imo.
        • pyroM!KE
          • 379
          #64
          Getting her dialed in.. This is just one awesome boat! It handles sooo good..But, on the very top-speed pass, It starts to chime walk so I back off of it..At 0 to 90% throttle it runs smooth as silk without any chime walking or anything.The last little bit of throttle then it starts chimming..Could my ride height be too high for my top speed?...I would say its going about 50mph when it starts the chiming..Thats the only handling issue it has..Everything else looks awesome..When i hit a wake at about 3/4 throttle (around 40mph) and it catches about 1 foot of air it looks like a dart flying perfectly straight..Its an awesome sight..
          Also my electric's - prop setup is working awesome..the hottest temp I saw was 138 which was the motor bullets..Everything else was 110 and below..Im soo happy with this boat!
          Graphics done..I need to figure out a way to secure the hatch..Thats the only thing I need to do to complete..Ohh and Im gonna shorten esc-motor wires and install 8mm bullets..Heres some more pics..
          • Drax21
            • Jul 2011
            • 1077
            #65
            So your running on 6s and top speed is 50MPH? I would think it would be near 60. Shows 59 using this http://www.offshoreelectrics.com/conversion.htm I had the same problem with chime-walking on my Pursuit. It just means a little more weight is needed at the back. Could be done by increasing size of batteries mah (Costly). When I put my GPS in the back of my Pursuit, it gave it a bit more extra weight and the problem was gone. Resin can also add weight which I have done in my Cyber Storm.
            I would really like to see a video. Boat is looking great btw.
            • pyroM!KE
              • 379
              #66
              Thats just at 90% throttle (50mph)..I have yet to make a saw pass to get top speed..I dont want to blow her over again..But I will say that when I get her dialed I will be in the 60's..Im gonna try to lower the transom on my next run..My stinger is perfectly level so I will add a +deg or so to try to get her a little wetter..It dosent chime all the time..Just when I hit 50 mph +..I think its because the prop and rudder is the only thing wet...Damn this thing is fast!!!!
              • Drax21
                • Jul 2011
                • 1077
                #67
                Ah that's cool. Sound like your enjoying the boat. +deg is good. I have mine just off level from the boat. About 3 degrees.
                • pyroM!KE
                  • 379
                  #68
                  Got some awesome runs in today. I was able to run her full throttle the whole time.Im getting her trimmed out without using trim tabs..I shimmed the stinger .015" to the left to get her going straight with the rudder perfectly neutral..She Still wanting to go to the right a bit so Im gonna shim her up to .025" and that should do her..Got my cg at about 31% (about 9.75 inches from the transom)..Shes loving it..Wide open runs with turns and all..Flys like its on rails.. When my son gets home Ill get some good video of her running.. I wish I had a GPS but Ill guess mid to upper 50's..
                  Its nice to just grab a handfull of throttle and not worry about losing control..I think Im gonna sell my trimtabs I got cuz Im not gonna need um.. :)
                  • Drax21
                    • Jul 2011
                    • 1077
                    #69
                    Originally posted by pyroM!KE View Post
                    Got some awesome runs in today. I was able to run her full throttle the whole time.Im getting her trimmed out without using trim tabs..I shimmed the stinger .015" to the left to get her going straight with the rudder perfectly neutral..She Still wanting to go to the right a bit so Im gonna shim her up to .025" and that should do her..Got my cg at about 31% (about 9.75 inches)..Shes loving it..Wide open runs with turns and all..Flys like its on rails.. When my son gets home Ill get some good video of her running.. I wish I had a GPS but Ill guess mid to upper 50's..
                    Thanks for the precision on details. Will probably help when I finally get mine going. Just seems to pour with rain everyday here....
                    • pyroM!KE
                      • 379
                      #70
                      No prob..Tweaking on these and surfing the forums is half the fun..Now...Get that boat in the water!
                      • pyroM!KE
                        • 379
                        #71
                        Got some more runs today.. WOW!!! I did a high speed submarine and lost the boat for like 4 sec..Had my stinger adj a little to high..Also I shortened the esc-motor wires and installed 8mm bullets..It made a substantial difference with the wire and bullet change..The temps dropped..Especially the esc-motor wire temps..I was seeing wire temps of 170+. Shortened the wires and added the bullets and now the wire temp is 140's...Esc, motor are in the 110-130 range..Batts are 100..
                        Ohh and the submarine caused the top of the hull to crack a bit..I wish I had it on vid but you can see the cracks in the pic..
                        • pyroM!KE
                          • 379
                          #72
                          I still need to install the .025" shim on the stinger cuz Im still getting some prop walk (I think I can get 1-2 more mph here getting the prop walk eliminated) but I had a day, let me tell you..Took her to the city pond..Ran it hard for 2 minutes..Hottest temp I saw was 138 and that was the esc caps..Looked up and the cops showed up..First thought was, damn..That lady walking her dog called the cops..Well that wasnt the case..Cops were like Whos got the speed boat(there was 2 cop cars show up)..I was like me. Then he said why isnt it in the water..Then I laughed and was like heck yes..But then it hit me..I had just used my packs I had charged, but I decided to do 1 or 2 more passes on the packs that had 2 minutes on them..According to there radar guns, I got a 57.4mph run on a set of discharged packs (dont worry I didnt discharge too low)..I think with fresh packs the OSE speed calculator was pretty close..I figure I can get 60 with a freshly charged set..And jezz..I did a 2 minute run and like 6 or 7 people driving by stopped to see WHAT THE HELL WAS ROOSTER TAILING ACROSS THE POND!! LOL
                          My setup is :
                          SK180
                          Leo 4082 1550
                          Octura X447/3 B/S DASBOATA
                          6s2p 6000mah 40c turnigy (2 3000 mah packs parallel totaling 6000)
                          One thing I will say is I did see temps over 140 (on hard runs around 3 minutes,esc was 135 motor was 145 wires were like 168) but that was with 5.5 motor bullets and non-shortened wires..
                          A tip Im gonna pass on is if your gonna run this power setup, run 8mm bullets on the motor wires(or possibly solder motor wires directly to esc),shorten all wires as short as possible, and run battery connectors similar to what I build..With these mods Im not seeing any temps over 130's.Batteries were 105.. Weather or not you can achieve 57mph on a 4 or 5s setup more efficiently with this hull, I dont know? I almost want to try 5s with a X450/3 but I dont think it would be any faster or efficient.. Also I dont think racing situations would be good either with this setup(it might be if you had a x447/3 cut to a 46mm and some MPH would be lost)..But obviously I didnt build this to race with, I built it for speed-bashing runs reliably (Spartan crusher opps did I say that out-loud) and I believe I have achieved that..
                          So,all in all, I think my setup on 6s with this hull, is about as extreme as I would go..I just dont think the hull could handle much more than Ive been giving her.BUT.So far so good..
                          • pyroM!KE
                            • 379
                            #73
                            Double post? I dont know how that happened.
                            • Drax21
                              • Jul 2011
                              • 1077
                              #74
                              You definitely crushed the Spartan Mike! That sounds like a fantastic day! Cops n all.
                              • Drax21
                                • Jul 2011
                                • 1077
                                #75
                                Got my 1st run in today, expected something special but......
                                See my thread for link to video. Probably will just need a few tweaks.
