No offense taken LD. I just prefer to give advice with caution. And, am a firm believer that the cost of an extra $15 prop or two and working your way up is cheaper than a $150+ motor. I also tend to prop my own stuff to live through a two minute full throttle run. Boats being run in sport conditions of on the throttle off the throttle can usually stand a little more prop but running the 1/6 mile oval where the trigger gets pulled and held for the duration of the race tends to get things a bit warmer.
I'm also a little confused by the boat running 6s 2p using 2 5000 ma and 2 2650 ma packs. If it's 6s 2p I'm guessing all the packs are 3s then run series and parallel? IMO mixing ma or even c rating in a parallel setup is inviting trouble as well.
