Wolf in Sheeps clothing
  • Jacked1
    replied
    Originally posted by Chris Harris View Post
    This brings back a lot of memories. The Traxxas Villain IV was my first R/C boat. I bought mine way back in 1989!
    I had a lot of good times with that boat, tried my best to wear the bottom off her. LOL
    Cool project, looking forward to some video!
    Chris
    It was my first boat too! But I was born in 1989... haha
    This should be pretty cool! Isn't this your 3rd Villian?!
    I have some uses for those metal U jounts
    Leave a comment:
  • cenracer
    replied
    Going to have to follow this one closely as I am doing the same thing to my Villain IV... Glad to see I'm not the only one here who wants to do this.. My boat is pretty close to the same age as yours..
    Leave a comment:
  • Jesse J
    replied
    Thanks guys! I had to do some major hunting to find all the upgraded driveline pieces....................got the bearings from one place................5mm steel rod from another.....................Steel U-joints from ebay...................Exact factory gearing(28t x 14t) in steel from Tower hobbies..............................etc, etc...............
    I settled on the 2600kv on 3s for this reason. 2600 x 11.1v nominal = 28860. Stock titans in the EX version are 1700kv x 14.4 = 24480. I didnt want huge rpm's, but i'll be spinning sharp, non-flexing 447's and can go up to in pinion teeth easily.............15, 16, 18 etc.................... for more speed if she can handle it.
    Jesse, what is your setup again..................it was a more scale, bit milder brushless build right???
    U-joints, he's got some other cool stuff too - http://www.ebay.com/itm/220651732994...84.m1439.l2649
    bearing pics...........
    ha! milder? how about STOCK!! oh ya, the only upgrade is fiberglass hull, some paint and an EVX2 speedy. same stock Villain IV motors..... I know, tisk tisk. but .... until I get my trailer back from my buddy up in Montana, upon whenst I can perform a true boat launching with my Topkick crawler as the main man, I doubt I will spend much time on her. Besides, I should let you get all the beta testing done, so I can saunter on back to this thread and hit all the juicy tidbits you are so graciously providing!
    until then, I will be right here riding shotgun!
    Leave a comment:
    replied
    Very cool bro!
    tagin along on this one....
    Leave a comment:
  • Chris Harris
    replied
    Chris
    Leave a comment:
  • NorCalZ71
    replied
    I think I might just have to beef up the stock drive system on my ex. And while I'm at it convert my single drive to 5mm. Gotta find someone with a lathe to turn down the end to 3/16
    So I can use standard props tho.
    Sent from my T-Mobile G2 using Tapatalk
    Leave a comment:
  • Alexgar
    replied
    When doing my nitro vee conversion I found mine at graupner u joints that is
    Leave a comment:
    replied
    Oh........here are the 4mm to 4mm that i think you will need Jesse.
    http://www.ebay.com/itm/universal-jo...item2568bff353
    Leave a comment:
    replied
    Leave a comment:
  • NorCalZ71
    replied
    Subscribed! Gonna have to steal some of these mods for my EX!
    Leave a comment:
  • Jesse J
    replied
    Ohohoo ya! Now were talkin! I will need to know where I can get the metal u joints.
    One thought: since you are increasing the power by an order of magnitude, you may think about striping off the lift strakes ?? I would also want pretty deep fins on the drives. Looks like a fun project!
    Leave a comment:
    started a topic Wolf in Sheeps clothing
    Been long enough for me to start a new project...................going back to my original passion that started me out with boats.................modding the elegant, scale looking, Villain IV. Found a pristine 1 owner on ebay a couple weeks ago.
    Fairly tame and conservative in appearance, this 20 yr old, 31" Deep Vee will seem like easy prey for the modern FG brushless boats with its ancient dual outdrive system.
    But what if I were to:
    -Swap the 20T brushed stinger motors with their 80 watt output for a couple 3656 2600kv brushless motors putting out 700 watts each?
    -Change the driveline from 4mm to 5mm to handle the power?
    -replace the stock plastic drive gears with steel pinions and spurs?
    -Add 5mm flanged bearings to support the 5mm shafts thru new large diameter brass tubing?
    -install some steel U-joints in place of the plastic noisy ones?
    -Swap out the 4mm short shafts for 4mm to 3/16 drives to accept some real props?
    -Yank the plastic 2 piece props and throw on a set of shiny, sharp counter-rotating x447's?
    Well.......................thats what i'm gonna do
    Sneek peek:
