Been long enough for me to start a new project...................going back to my original passion that started me out with boats.................modding the elegant, scale looking, Villain IV. Found a pristine 1 owner on ebay a couple weeks ago.
Fairly tame and conservative in appearance, this 20 yr old, 31" Deep Vee will seem like easy prey for the modern FG brushless boats with its ancient dual outdrive system.
But what if I were to:
-Swap the 20T brushed stinger motors with their 80 watt output for a couple 3656 2600kv brushless motors putting out 700 watts each?
-Change the driveline from 4mm to 5mm to handle the power?
-replace the stock plastic drive gears with steel pinions and spurs?
-Add 5mm flanged bearings to support the 5mm shafts thru new large diameter brass tubing?
-install some steel U-joints in place of the plastic noisy ones?
-Swap out the 4mm short shafts for 4mm to 3/16 drives to accept some real props?
-Yank the plastic 2 piece props and throw on a set of shiny, sharp counter-rotating x447's?
Well.......................thats what i'm gonna do
Sneek peek:
Sneek peek:
LOL
how about STOCK!! oh ya, the only upgrade is fiberglass hull, some paint and an EVX2 speedy. same stock Villain IV motors..... I know, tisk tisk. but .... until I get my trailer back from my buddy up in Montana, upon whenst I can perform a true boat launching with my Topkick crawler as the main man, I doubt I will spend much time on her. Besides, I should let you get all the beta testing done, so I can saunter on back to this thread and hit all the juicy tidbits you are so graciously providing!
J/K That's the year I graduated High School LOL
