Wolf in Sheeps clothing
  • cenracer
    • Oct 2011
    • 15
    Will do, Make a wake.. I just finished helping my son set up another quad copter.. He's into these things.. and then its off to the boat. We just got dumped on with 16 inches of snow saturday into sunday so boating is out for a while.. Lost power for a while and just got it back... I have to start somewhere.. what would you recommend for motors and speed control? I'm looking to keep cost down on this one.. Looking for good speed, mid 30's would be good..
    • Make-a-Wake
      FE Rules!
      • 5554
      I dont know how much farther you can keep the cost down than the 16 bucks i spent for each motor..............brand new too! Crazy cheap for a decent motor in my book
      http://www.hobbyking.com/hobbyking/s..._Inrunner.html
      Speedo's were only 34 bucks apiece - http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
      and batts a paltry 23 each - http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
      I think i was a pretty good shopper!
      • Jesse J
        scale FE enthusiast
        • 7241
        Yes, but do you have reverse?
        "Look good doin' it"
        See the fleet
        • Make-a-Wake
          FE Rules!
          • 5554
          Yep, and the solid shafts allow use of it!
          • Jesse J
            scale FE enthusiast
            • 7241
            you ARE a dawg! Now it might be time to follow your lead - I never really liked the EVX2 set up as it was in there. Looks like I have a Christmas list for me started...
            See the fleet
            • Make-a-Wake
              FE Rules!
              • 5554
              I use EVX's in land rigs.................even the marine version..............i just pull off the rubber cooling thingy...................they are great ESC's for 12-14 cell nimhs or 4s lipos. Building a semi scale Tundra with an Emaxx chassis using an EVX2 and a single Graupner 700 8.4bb on 14 cells.
              • cenracer
                • Oct 2011
                • 15
                Make a wake.. I was looking at those motors and the same esc.. thats what I was going to use.. I might go for larger batteries (5000) but that would be the only change.. What kind of speed do you think you can get out of that setup?
                • Make-a-Wake
                  FE Rules!
                  • 5554
                  Since the hull is certainly "limited" in speed i'm thinking low 40's would be my goal............................we'll see.
                  • cenracer
                    • Oct 2011
                    • 15
                    Mid 40's or anything close to that will be perfect. I don't expect it to go any faster, I was just hoping it would get out of the lower 30's.. I have a lot of experience with fast r/c, although ground and air based.. water will be my next challenge.. I love to push the limits of things that were not designed to go very fast.. LOL
                    • Make-a-Wake
                      FE Rules!
                      • 5554
                      Some more done............been a bit busy so a little on the slow side for this build.
                      1st pic - Motor mounts back in and larger diameter brass tubes now installed
                      2nd pic - I used the stock transom holes but had to bore them out a bit, still used the stock rubber gaskets(stretched just a tad) for sealing the holes around the tubes, looks clean.
                      3rd pic - New brass tubes extend out a little farther than stock due to the new steel u-joints being a few mm shorter, 5mm bearings installed.
                      4th pic - 5mm i.d. and 8mm o.d. bearings popped in tightly................like it!
                      • NorCalZ71
                        • Jul 2011
                        • 293
                        Looks sick!. I'm gonna have to start collecting parts for this build as soon as I get the hornet running right.
                        Sent from my T-Mobile G2 using Tapatalk
                        • Make-a-Wake
                          FE Rules!
                          • 5554
                          Thanks Kevin, just cant get over how small these bearings are, close up pic of one here..............cost me about 3 bucks each.............had to have a $50 minimum order from the co. i bought them from.
                          Blowup of bearing:
                          • NorCalZ71
                            • Jul 2011
                            • 293
                            Damn.. so I take it u bought more then just 4 of em?.
                            • Make-a-Wake
                              FE Rules!
                              • 5554
                              Yeah, got like 16 or so.......................got backups.
                              • NorCalZ71
                                • Jul 2011
                                • 293
                                Lolz thats always a good thing
