JAE Builds
  • Xfactor
    • 874
    #181
    Any experience with the jae 45 Smock?
    • Xfactor
      • 874
      #182
      What would you charge me to build some Jae 45 H-sponsons?Can you add adjustability on the booms not width but aoa?Like you see here on my c class mongoose.
      • Chilli
        • 3204
        #183
        Originally posted by BakedMopar View Post
        Does both sponsons have the same AOA?
        Yes, they are identical.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • Eric Bourlet
          • Jan 2010
          • 104
          #184
          The sponsons are actually the same as stated above. In fact I cut mine out together by stacking and tack gluing the foam and wood laminate for two spnsons prior to cutting out on the band saw. You can look at these plans and see.
          Eric Bourlet
          Team Airtronics
          Team M&D Designs
          • donthavta
            • Jul 2009
            • 188
            #185
            Great info
            Great info on this thread. I've been in boats for 45 years ,BUT this is my first rigger (ordered today) . When finishing do you glass? Jae strut looks like it will drag? Thanks for all the great info Ron Squires
            • Doug Smock
              • 5359
              #186
              Hi Ron,
              No glass on these. Just two or three coats of finishing epoxy.
              Congrats and good luck!!
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • Xfactor
                • 874
                #187
                Mr smock did you forget me?
                • 6S HYDRO
                  • 1325
                  #188
                  i did lay some glass on the rear of the tub only, where the stuffing tube runs thru
                  • Doug Smock
                    • 5359
                    #189
                    Yes sir I sure did. Very
                    No I haven't built a 45. I am making plans to build a modified (tub) gas version.
                    I'd like to help you out with a set of sponsons, but I have some other projects that need my attention.
                    We can talk in the fall if you still have the need, ok?
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • donthavta
                      • Jul 2009
                      • 188
                      #190
                      So! Witch prop are you guys running , with U-L or Blackjack motors. Ron
                      • Doug Smock
                        • 5359
                        #191
                        Two down.....
                        Well I shipped out two of the builds this week. Took some pics before I boxed them up.
                        The third one is staying local and I'll be putting a real P-Limited setup it. I'll post some pics of that one too.
                        Ron, with the UL-1 motor and esc you'll be happy with a Octura 1450 or ABC H-7. The boat will run good and you won't punish anything
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • HOTWATER
                          • 2419
                          #192
                          Doug
                          Top notch as always with you Doug!! Hey, I really like that cowl...
                          -Kent
                          "Will race for cookies!"
                          IMPBA D12
                          • BakedMopar
                            No Mo Slipah
                            • Sep 2009
                            • 1743
                            #193
                            Looks awesome! Will the vacu-boat cowl fit if the top peice is not cut for a single cowl? I got one coat of epoxy on the tub and sponsons. Thanks again Doug.
                            Aloha
                            • HOTWATER
                              • 2419
                              #194
                              Aloha
                              Just cut out the top skin strip dividing the two...I did that to mine and it worked out fine!
                              IMPBA D12
                              • Doug Smock
                                • 5359
                                #195
                                Thanks Kent.
                                Yep what he said George!!
                                Doug
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
