JAE Builds
  • Chilli
    • 3204
    #91
    I don't know if all the HD's are the same, but I found them in the metal drawers toward the middle of the hardware aisle.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • Darin Jordan
      • 9446
      #92
      Originally posted by Chuck E Cheese View Post
      why do you need washers? i just push the colars tight against the tub
      On my Raptor... the washers are sealed to the tub with Silicone to seal the boom tubes...
      Darin E. Jordan - Renton, WA
      • Doug Smock
        • 5359
        #93
        I'm using them to protect the finish on the tub.
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • Chuck E Cheese
          • 2136
          #94
          i understand, on mine the boom tubes are tight and i push the collars tight so if they do move at all they can only cause small scratches under the collar and i am not worried about scratching it where it cant be seen.
          i did use nylon washers to seal the motor mount bolts and space them away from the cooling jacket. i put a metal washer outside a nylon washer against the hull.
          • HOTWATER
            • 2419
            #95
            Originally posted by D.Smock View Post
            5/16 ID X 11/16 OD x approx 1/16" nylon washers. I found them at my local Home Depot.
            Doug
            Thanks Doug! I like the way that it protects the finish...nothing major, just something that I liked about your build.
            Thanks Darin...don't know if I will tack them to the tub with sillicone, but that is a good idea...
            -Kent
            "Will race for cookies!"
            IMPBA D12
            • Doug Smock
              • 5359
              #96
              Test vid from yesterday for those interested.
              I LOVE THIS BOAT!!
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • HOTWATER
                • 2419
                #97
                I LOVE THIS BOAT!!
                Looks like you have a great heat racing setup...consistant!...
                -Kent
                IMPBA D12
                • Doug Smock
                  • 5359
                  #98
                  Thanks Kent,
                  Here's another one, http://www.youtube.com/watch?v=pNbIuZp9HKk
                  I should have it nailed down next weekend.
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • Trini
                    • 164
                    #99
                    2nd video the boat looks awesome Doug. Keep up the good work you are very very close to where you want it to be.
                    Atlanta Model Boaters
                    District 13
                    • Doug Smock
                      • 5359
                      #100
                      Thanks Trini,
                      You need to come run some laps with me this weekend. By then I'll have a box full of this and that, we'll fine the "right" prop. lol
                      BTW when we do, it's MINE.
                      Smock
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • Jeepers
                        • May 2007
                        • 2050
                        #101
                        right" prop. lol
                        Smock
                        Hmmm if I were Trini I would play a little joke on you and sneak a small prop on your boat just before the next heat.
                        • Doug Smock
                          • 5359
                          #102
                          Still making progress and having a ball!!!!!!
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • RayR
                            @SiestaKey.calm
                            • Jun 2007
                            • 1591
                            #103
                            I do believe that is the "right" prop. Now, WHAT WAS IT!
                            All the best,
                            Ray
                            • Chuck E Cheese
                              • 2136
                              #104
                              i did some testing this weekend also. the h-7 was good, but i got a 1450 modded by mark sholund and i think that is the last prop i need to test. dont have any video yet but it runs good with the correct lift and tempaturs still in the 110 degree range.
                              • HOTWATER
                                • 2419
                                #105
                                Hey Chuck!
                                Was the H-7 also done by Mark or was that one just S/B (out of the bag)? Glad you're running well!
                                -Kent
                                IMPBA D12
