I need help with my geico 29!!!!!!!!! Please
  • rude5150
    • Feb 2014
    • 339
    #61
    • rude5150
      • Feb 2014
      • 339
      #62
      BLACKJACK is a much better hull than GEICO . Can u guess my speed?
      • rude5150
        • Feb 2014
        • 339
        #63
        No feed back yet? Whats the fastest I can go in s 29" cat?
          I have been over 60 but... There seems to be a real wall at about 57mph. The speed which it really likes being an airplane.
          • Luck as a Constant
            Make Total Destroy
            • Mar 2014
            • 1952
            #65
            I dunno, are you alright?
            No I did not see your video.
              Make Total Destroy
              • Mar 2014
              • 1952
              #66
              ok i watched. looks like high 40s maybe i dunno. buy a gps and stop asking us how fast your boats look all the time....
              • Rumdog
                • 6667
                #67
                Uhhhhh... Its the same hull
                  When I read that I was like....lmao. same hull...different paint scheme. Lol
                  Same think like the Motley crew and Lucas oil. Same boat, different paint scheme.
                    With that hull....maybe 60 but you better know what your doing. It like to take off the water at 60
                      Unfair! How did you get such big screen time? Talk about free publicity!
                      Hi Rude5150!
                      I could not give you a meaningful feed back because I could not tell how your boat is doing with the way it was driven ---not a criticism but there are too many other boats/ and sail boats in the pond, you could never stretch your legs, it gets frustrating for the viewers. Go to a bigger pond and peg that throttle.
                      My guess that your speed is in the low 40's, sorry, but initial launch always gives a somewhat faster impression and you had many launches.
                      I have done 53 mph, but no attempts were made by yours truly to go faster. Stock it will go mid to high 40's, unless you are a very experienced FE boater, I am not in that league and it is a satisfying feeling to know where I stand in the food chain of FE boating. lol...
                      • rude5150
                        • Feb 2014
                        • 339
                        #71
                        Wow, got me. I just got a GPS and I had better be doing more than 40-50.
                        • rude5150
                          • Feb 2014
                          • 339
                          #72
                          Blackjack hull is flat with surface. Geico is bent-up, usually needs blueprinting.
                            Ooooo....so they form the bj hull in a different mold than the geico hull? Sounds legit. Lol
                              I'll give you a little info because I know a little bit about fiberglass and carbon work. If Temps are different between when the two hulls are layer up, you'll get slightly different results. If you don't wait long enough to pop it from the mold, it may not be fully cured and then may warp a little. You just lucked out and got a better hull because of variables. The only different between those two hulls is the paint scheme. The blackjack does come with an offset rudder, higher amp esc and a 1800kv motor vs the 1500kv in the geico.
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #75
                                There you go.
                                It's important to use a long stretch of water and holding full throttle for a good distance to get an accurate gps reading
