1/6 scale Jetsprint boats and 30mm Jet drives
  • TheShaughnessy
    • 1461
    #76
    I used to run a first gen SV motor ( blue can ) and AQ 45 amp esc in a 29 mm graupner unit. No actual numbers logged but that set up never got hot and it was In a 31 inch mono. Still working on getting some cash together before I can order one. Need a charger and radio first though. I have eagle tree so if I ever get one ill gladly post up some amperage numbers.
    • monojeff
      • Nov 2010
      • 2728
      #77
      I also have Eagle Tree and can log some numbers.
      I planned to try out a Proboat 1500kv motor on 4s & 5s.
      I think it will be a perfect setup for this given the size of the boat.
      Looking forward to this a lot and I know they will be a big hit!
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • monojeff
        • Nov 2010
        • 2728
        #78
        Is this jet unit able to go in reverse?
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • Fella1340
          • May 2013
          • 1025
          #79
          No reverse bucket, no reverse.
          • monojeff
            • Nov 2010
            • 2728
            #80
            Thanks I didn't think it did but I am still learning.
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
            • Fella1340
              • May 2013
              • 1025
              #81
              I only learned it through this thread and comparing options. I didn't think it was important option to have and I think it would require another channel on the radio anyways.
              • TheShaughnessy
                • 1461
                #82
                Because electric motors are able to change rotational direction without a transmission I bet if you spun the impeller in reverse you would be able to go backwards a bit. But who is using reverse on an rc boat?
                • mickieb49
                  • 256
                  #83
                  From all the times I wired up the motor in reverse, I do not recall that the boat ever reversed. I am sorry to say that if you wanted a boat to go in reverse then this jet unit is not for you. Please I say that in utmost respect because I would hate you getting anything that doesn't fit your requirements. This unit requires 3 channel radio, so you can trim the boat as you go, also mix the trim function in with your steering, so when you do a steering input, the nozzel points down by a few degrees , pushing the nose back in the water so it turns better.
                  Remember , No power, No steering!
                  Regards mick
                  • monojeff
                    • Nov 2010
                    • 2728
                    #84
                    Regards mick
                    Great info as said most R/C boats would not require reverse it was more of a I wonder type of question.
                    Keep up the great work Mick!
                    OSE GIFTING ELF
                    HAPPY HOLIDAYS!!
                    • monojeff
                      • Nov 2010
                      • 2728
                      #85
                      what type of servos are currently using?
                      OSE GIFTING ELF
                      HAPPY HOLIDAYS!!
                      • mickieb49
                        • 256
                        #86
                        Hi I am using hitec STD servos, even micro servos would have enough grunt to be used.
                        I just moved the c of g backwards, helped a heap, one of my mates was filming, he will post the video later on.
                        Cheers mick
                        • mickieb49
                          • 256
                          #87
                          here you go guys, was a bit rough yesterday , but bringing the c of g aft helped heaps.
                          • Darin Jordan
                            • 9446
                            #88
                            OK, too cool... where do I get one! :)
                            Darin E. Jordan - Renton, WA
                            • mickieb49
                              • 256
                              #89
                              Hi Darin, just pm me with your postcode, state, town/suburb. And I can get a quote for shipping.
                              Just got a quote the other day to send a hull/jet unit combo over to the states and it was $85 AUD, I will add though if the actual cost comes back cheaper then I will refund the difference in full.
                              Still finishing off the cowl mold, so it may be a few days before I can get a hull completed.
                              Regards mick
                              • mickieb49
                                • 256
                                #90
                                psy.jpgpsyc.jpgpsych.jpgpsychot.jpgH Guy's, Just a little update, just got some paint on the hull, and the first 2 production hulls will be ready to ship out to some lucky customer in the next few days, by t he way these will be up for grabs.
                                Got the skipping sorted, changed the C of G and removed the lower lifting strakes, will get some video soon
                                Cheers Mick
