1/6 scale Jetsprint boats and 30mm Jet drives
  • mickieb49
    • 256
    Hi Guy's,
    Not too sure if this is the correct area to post this thread but i have bbeen working on production of a 30mm Jet unit, it has a 30mm dia Alloy impeller, ABS body, Trimmable Nozzel. This is a Mixed flow jet and has a much better performance than the Graupners and KMB units out there.
    I am looking at releasing the units within the next 6-8 weeks as i am now waiting for the injection molds to be completed, They will also have the availability of being transferred into a 2 stage unit with only an addiition of another set of impeller/ flow straightener and a connecting ring.
    Also due to be released will be 2 types of hulls to suit the jet units , they will be a 1/6 scale 650mmm long jetsprint, and a 850mm long Marathon river race jetsprint hull, these hulls will be vacuum formed ABS, construction will have to be done by the purchaser, pictures of the huls will be a few weeks away, i have attached some 3d prints of the jet units so you get a look at them.
    I haven't set the price in yet but thinking somewhere around the $130-150USD ea? Hulls will be around the $130USD Ea mark.
    Regards al Mick
  • Basstronics
    • 2384
    Pump looks awesome. Price seems a bit high for ABS hulls?
    • mickieb49
      • 256
      Originally posted by Mike Caruso
      Mick,
      So glad you are working on a pump. How efficient will to be? Will you be listing the thrust, motor used, ESC and batteries used in your testing? Can't wait for a good one that everyone can run.
      Good luck.
      Mike
      Hi Mike,
      I'm not too sure how to measure the thrust, but i will certainly try my best to report on everything about them once they are ready. I was going to use a Leopard 4074 1600kv motor with a 120 amp esc on 4s lipo. These units have been a work in progress for over 10+ years and have only become a reality now. The performance will match the effeciency of the larger cousins of the Swashdrives and Jettecs, as it is a mixed flow pump with overlapping blades and the trimmable nozzel. I am doing a initial run of 1000 units.
      As for the price on the hulls it isn't locked in concrete yet but you will get a Alloy rollcage, SS jetunit cover, and 2 prepainted drivers, So it isn't just the bare hulls, i will offer infused carbon hulls at a later date but that is dependant on the demand.
      thanks for looking guy's, i will be updating this thread as the news becomes available
      Regards Mick
      • Basstronics
        • 2384
        OK now that sounds more like it!
        I will be watching for updates. Always wanted a jet boat.
          Mmm,good work on the jets. I had done a load of research in hopes of building my own many years back. Glad to see fruitition I imagine Mick . I shall be very interested as I love my NQD(bit small) and have a 28mm in a scratch built flatbottom( my avatar). I look forward to the release and pics.
          I don't know if a 120 will quite be enough though you shouldn't see spikes so much with a jet it does take a greater steady load to maintain pressure. I've been meaning to put the ET on the NQD.
          Great work,Shawn
          • TheShaughnessy
            • 1461
            Looks awesome. My first boat was a jet drive but the hull was too big for the drive. I've been wanting to build my own drive for a while now but don't have the time, money or knowledge really. I'll be impatiently waiting for the test video.
            • mickieb49
              • 256
              Hey Guy's,
              Thanks for the feedback guy's, it is most appreciated, and i will sure to be loading the first testing video once i get the time .
              Mike , at the moment i will only be releasing one impeller with it but i will be releasing different pitch ones at a later date, but for now i will be doing all the expensive research into motors and will report back with the best motor to suit this drive/impeller setup.
              If you have any questions please ask away.
              Regards Mick
              • TheShaughnessy
                • 1461
                • mickieb49
                  • 256
                  Not too sure if i follow you,
                  Jet units are still a little while off, the impellers will not be ready untill after the 25th so will not be able to put in an update untill after then, please remember i am making 350 jet units and about the same in boat hulls.
                  As i get some more updates i will sure to be updating here
                  regards Mick
                  • mickieb49
                    • 256
                    Mike, the jet units have already been tested, the testing I have to do is with the hulls, that is why I have a 3d printer, the jet unit I have printed out is not a fully functional unit but is enough to prove the design, and I have been playing around with impeller/ flow straightener designs for the past 10 years.
                    I really do not want the customer to be scape goats and work out any issues, this is simply not good business.
                    On another hand I have also been playing around with designs for a race hovercraft, the intent is use really cheap electrics and race them on the tidal sand flats round where I live, but also to provide a inexpensive but good quality entry into hovercrafts. I am going to vacuum form the hulls out of ABS.
                    Warm regards Mick
                    • TheShaughnessy
                      • 1461
                      Is that the 25 th of this month? Got a hull I wana try a jet drive in, was thinking a 29 mm graupner at first but then I remembered these.
                      • mickieb49
                        • 256
                        Hi Mate,
                        Yes that is the 25th of this month, but that is when the impellers will be finished being machined.
                        Got the first trial run parts of the jet units, got a few modifications to get done but it will not be very far off at all.
                        By the way, good luck getting a Graupner unit, as Graupner has folded and there will not be any more units or parts available soon. I will also have the hulls available soon, finished the bottom half of the mold, just got to do the top and the cowl then I will be making these in fiberglass , I will be supplying 3 different hulls, one that is about the 500mm long, 650mm long (Jetsprint hulls) and another that will be a Marathon river race jet boat 800mm long.
                        Warm regards Mick
                        • TheShaughnessy
                          • 1461
                          You are right about the graupner drives, didn't realize they went under. I know a guy that makes replacement parts, or at least he has made a part for me when I still had my 29 mm drive. Are you accepting pre orders? I'll buy one of your drives and do my own R & D on motors if you get one put together. Maybe you could cut me a lil break on your prototype and ill be sure to give you feed back.
                          • mickieb49
                            • 256
                            Hi, Thanks for the offer, and may take you up on that, as long as you will put your honest findings on the pump here for everyone to read.
                            I am still waiting for the impellers to be finished, plus the finalisation of the injection molds will hopefully be done very soon.
                            Will keep everyone updated as the progress continues.
                            Regards Mick
                            • Savage Skidoo
                              • May 2011
                              • 359
                              Iv'e been looking for a pump also , looks GREAT . Mike
                              www.facebook.com/Boaters and Crawlers Durham
                              Durham Off Road Rc Club - www.dorc.ca founding member
