56-102 Monster coming down the pipeline
This topic is closed.
  • Azmarine
    • 81
    #136
    Just ordered two proteus 524's gotta see what these baby's are about.
    That odd moment when you think, "Is RTR the way to go?" Then you see your hard work, and laugh at the thought.
    • Chris Harris
      • 186
      #137
      Originally posted by carlcisneros View Post
      Chris, those are the fightercat esc's by the way. made by Flier model.
      Yes I saw they actually used
      the Fighter Cat name in one of their product descriptions.
      I figured they were the mfg but I thought it was strange they were
      using the Fighter Cat name. I want to try the 90volt 400 amp, anyone have any experience
      with them?
      Chris
      I.M.P.B.A. Record Holder P-Hydro 111.001mph Q-Hydro 120.192mph S-Hydro 139.233mph
      • jcald2000
        • 786
        #138
        I've got 3 runs on mine, smooooth throddle, ran cool at 180 amps. But it doesn't float, neither did the rigger it was in.
        • carlcisneros
          • Jan 2010
          • 1237
          #139
          jcald: OUCH!!!!!!!!!!!!!!!!!!!!!!!!!
          crrcboatz: they are a good ESC which ones did you get?
          Chris; they are good units. keep them cool
          • crrcboatz
            • Jan 2009
            • 1103
            #140
            2 of the 3-16 x280amps and 2 of the 3-8 x 250 amps
            • carlcisneros
              • Jan 2010
              • 1237
              #141
              both series of esc are great units. the 250A unit is about as bullet proof as you can get.
              the 16S unit is a very good one as well. keep itcool.
              timing on both units:
              Delta: 3-5 deg. MAX
              Wye: 5-10 deg. MAX
              use the attached programming instructions.
              • carlcisneros
                • Jan 2010
                • 1237
                #142
                anyways, enough with high-jacking the thread, back to the movie.
                • keithbradley
                  • 3671
                  #143
                  5-10 degrees for a Y wind Carl? Is that a mis-print? I don't think I've ever seen a y that runs well at 5 degrees...
                  www.keithbradleyboats.com
                    What timing do you like?
                    Has anyone checked the motor constants to see how accurate they are?
                    • twissted
                      • 896
                      #145
                      To new motors on the way
                      So I bought the SKYRC marine 910 kv and the car 910kv motor. They claim that the car motor makes 10 hp! Does the marine duel kv motor make this much power?
                      twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
                      • keithbradley
                        • 3671
                        #146
                        Typically I find y winds to run well around 15 degrees. It depends on the situation, but I think 10 is usually about as low as you want to go on a y.
                        • lars_01
                          • 128
                          #147
                          Short video of a 130cm carbon mono with the HK 5692 1000kv and Flier 400A esc o 10S (4 HK 5S 5000mah) Motor:30 degress Esc: 16 degress
                          Batts:16 degress Cabels: 47 degress. Runing a Andy Brown 57/3 Water temp 10 degress.
                          Lasse
                          111
                          • carlcisneros
                            • Jan 2010
                            • 1237
                            #148
                            the 5-10 deg are for the ESC for those that are rather NEW to the FE market.
                            I usually run my esc's (Y wind motors) at 10-13 deg. nice and cool.
                            Ben and I tested and talked a long time about the timing on the FC HV units
                            and this is what we came up with for the new/new average boater to use so
                            that there would not be any (or very little)ESC smoking.
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              #149
                              Should a slight timing change cause an esc to smoke?
                              Steven Vaccaro
                              • carlcisneros
                                • Jan 2010
                                • 1237
                                #150
                                all depends on the motors used. ( i know about that one.)
                                It is mainly the outrunners.
