56-102 Monster coming down the pipeline
This topic is closed.
  • Punisher 67
    Ignore list member #67
    • 1616
    #106
    Maybe so but, they are far different than TP power of the same numbers... I think TP Power has splintered up. Johnny said he hired some guys from TP to make motors to his spec, not TP specs.
    Ray there is just not enough motor there to push those numbers without it ending up going kaboom........
      I know. I'll just keep propping until it gets to the edge in amps for my SF240. Should be interesting.. don't plan on breaking anything but, the motor is my last worry.
      • Punisher 67
        • 1616
        #108
        Ok....I just received the HK 1/5 buggy Trackstar and took it apart , The rotor is the same dia as the 5692's but is 71.5mm long . nice motor but it comes with a 12mm shaft and not the 8mm claimed . My take on this is HK ordered a bunch and someone got there wires crossed and made it with a 12mm shaft by mistake . Even the video on youtube clearly states a 8mm shaft with the guy holding the motor . like you can't be that stupid as not to notice the difference . I thought the picture on HK's website looked a little odd .
        I will post inside pictures of the motor and rotor when I get home from work tonight .
          Thanks for the info Peter.
            I'd still take one of these over that motor in a heart beat.
            • Punisher 67
              • 1616
              #111
              Pictures
                Nicely made. Carbon wrapped differing from the blue Turnigy motor (Kevlar wrapped) and much longer arm than the 5692's.
                Looks comparable to a 2028 eh Peter?
                • crrcboatz
                  • Jan 2009
                  • 1103
                  #113
                  How do u find a collet for a 12mm shaft! What is the kv of the HK silver motor?
                  • Punisher 67
                    • 1616
                    #114
                    As far as collet who knows ....??? Kv is 760 . The arm on a 5692 is 50mm and yes the arm is the same size as a 2028
                      Where did you get the black car motor Peter?
                      • twissted
                        • 896
                        #116
                        Well I ordered the skyrc Brand: SkyRC
                        Match for: Cars
                        Kv: 910
                        Shaft Diameter: Φ8 mm
                        Voltage Range: Up to 33V
                        Max Continuous Current: 190A
                        Max Continuous Power: 6300W
                        Shaft Length: 30mm
                        Practical r.p.m.Range: up to 30000
                        Weight: 1130g
                        I also ordered at the same time the
                        SkyRC
                        Match for: Boats
                        Kv: 910
                        Shaft Length: 30mm
                        Weight: 1035g
                        The top motor is for my Rampage XBE and the lower one is for my 58'' boat.
                        twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
                          Some of us are lucky enough to have the machines to make such things.
                            Match for: Cars Kv: 910
                            Shaft Length: 30mm
                            Weight: 1130g
                            I also ordered at the same time the SkyRC
                            Match for: Boats
                            Kv: 910
                            Shaft Length: 30mm
                            Weight: 1035g
                            Did you ever receive your esc from China? The Fighter cat one(s) you ordered???
                            • twissted
                              • 896
                              #119
                              So does this ancwer your question?
                                Awesome, thank you.
                                Can you possibly send me a link for the car esc? I sold a 1/8scale supercar to someone and the Neu 1527 pops 150 amp esc's.
                                Thanks again Twissted!!
                                [So does this ancwer your question?
