Cap banks - the pre-emptive answer
This is a sticky topic.
  • drwayne
    • 3012
    #46
    Originally posted by maxmekker View Post
    Well I have made a tread about the unsoldering stuff, and got so my ears hung down for my poor a.. soldering job. I have been soldering for ages, some 200 playstation chips, loads of para/serial connections, lipo packs etc for my boat's and flying buddy's, but all of a sudden my serial cabel wich I had used for a long time came unsoldered. Then I made another one with higher G wire, all fine on 45-90c lipo, and then on 65-130c unsolder again, and the boat feels slow so I'm willing to try everything to see if it helps.
    How looooooooooooooooooooong are your leads ?
    Anybody care to tell me what these little buggers do. One of them was 'eaten' on a bit, and was loose. No way I'm getting it to stick to the board again. So is it a rip on this 180 ?
    Take a close up of the top,and show what details are embossed.
    W.
    • drwayne
      • 3012
      #47
      Originally posted by Mike Caruso
      For one I would like to thank you because I love to learn! Now at 63 years old I REALLY want to run over 100 MPH more than just once. HA Mike
      You're most welcome.
      Run over 100mph ?.. I just wanna walk fast ..but that's a 2 bourbon story.
      • maxmekker
        • 466
        #48
        'How looooooooooooooooooooong are your leads ?'
        hehe, I have both (now) while I did some new ones I did both a short and a longer one. I'll make a super short one and flip the lipos the other way with the wires comming out closer to the ESC.
        Question, again, how about making the serial like it is on the stock esc that comes with the proboat mystic/geico.. Will it mess up the cell count( I don't use auto) you think , since it's a bit hard to plug both lipos at once if I make the serial on the ESC. Go bullet you say. Well I like the safety having a serial cabel made.
        'Take a close up of the top,and show what details are embossed.'
        Will make a zoom pic when back from work. But it has a grove into it where there should be a tiny solder point.
        Drammen rock City
        • drwayne
          • 3012
          #49
          [ATTACH=CONFIG]83536[/ATTACH]
          Yukko
          Dean's connectors ( and clones ) are best suited under 4S 80A.. they gain resistance under high load ( they heat up quickly )
          Your series connectir great.. for a low draw setup.
          try something like this attached for shorter total lead length. fewer plugs.. and use 5.5mm plugs for higher Tx with lower dTemp.
          Waiting for your pic !
          W
          • maxmekker
            • 466
            #50
            I use ec5 on all. I use deans in my 1/16 tanks only :-)
            I have looked at the bullet type connection you have a draving off there, I'm afraid it will blow up on me when I mess it up ( it will happend :-)
            my system is t180 leo 4074 2000/2150kv 4s 45-90c / 65-130c ,640, 642 m445 props. Should be in the safe zoone.
            pics later man, thanks for helping out beond the tread issue
            Drammen rock City
            • drwayne
              • 3012
              #51
              If you cannot solder 5.5mm bullets, your friends are correct about your soldering technique !
              If you're worries about plugging it together wrong. pay attention!
              and ..
              batteries ...
              female5.5 on battery positive
              male5.5 on negative.
              esc
              positive is male5.5
              negative 5.5female
              whatever number of series cells you use.. they will all 'daisy chain' together to feed your esc.
              Just be wary that last inline connection .. ZAP!
              It's good keeping some topical posts on this thread.. keeps it at top !
              and some others may gain help from the info.
              W
              • maxmekker
                • 466
                #52
                are you mokking me ? hehe :-) I can solder bullets. it's what you say next, '' If you're worries about plugging it together wrong. pay attention!''
                I know how it's done, it's just bullet proof with serial, and the system I have is not like a SAW boat so it should be ok. Maybe in the winter month's here in Norway I will sit down and convert over to bullets.
                Drammen rock City
                • drwayne
                  • 3012
                  #53
                  My daughter wants permission to write an educational mockumentary about this thread's participants ...
                  • maxmekker
                    • 466
                    #54
                    Here you go doc.
                    Drammen rock City
                      I know how it's done, it's just bullet proof with serial, and the system I have is not like a SAW boat so it should be ok. Maybe in the winter month's here in Norway I will sit down and convert over to bullets.[/QUOTE]
                      You should "bullet proof with bullets" drwayne is right, I made the change and never looked back. When I connect, I make sure my ex-wife is not around so my mind is in sound condition.
                      By the way, that thing fell from you ESC, the close up picures look like it fell from outter space. I too want to know what is it. I am learning alot from this post!
                      • Steven Vaccaro
                        Administrator
                        • 8934
                        #56
                        great thread! Thanks Doc!
                        Steven Vaccaro
                        • drwayne
                          • 3012
                          #57
                          Here you go doc.
                          That's rooted, mate !
                          hahaha
                          I hope someone with a T180 can supply us with the details as embossed on their undead Surface mount capacitors .... ??
                          That being said.. a 47pf ceramic cap would do nicely as an alternative.. ensure the existing remnant(s) are removed before you add new.
                          Very pleased to spoon feed information to an appreciative audience, Steven.
                          0¿0
                          W
                          • egneg
                            • 4759
                            #58
                            hahaha
                            0¿0
                            W
                            Nothing visible Doc.
                            IMPBA 20481S D-12
                            • properchopper
                              rcgoatbuild@snotmail.com
                              • 7708
                              #59
                              hahaha
                              I hope someone with a T180 can supply us with the details as embossed on their undead Surface mount capacitors .... ?? That being said.. a 47pf ceramic cap would do nicely as an alternative.. ensure the existing remnant(s) are removed before you add new.
                              0¿0
                              W
                              This is an early (non "additional cap board equipped) T-180
                              • maxmekker
                                • 466
                                #60
                                OK, so one of these would be ok to replace the broken one ?
                                Do they go on one way ore another ore is it same same ?
                                Now to find one localy
                                Drammen rock City
