King Of Shaves C1 Brushless!
    • 9481
    #106
    same ole video
    • RCprince
      • Jul 2007
      • 1684
      #107
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • Jeff Wohlt
        • 2740
        #108
        Mine is uploading now. Damn 180 meg file because I could not convert it to mpeg4 for some reason.
        You do not need the same brand of lipos to run you do not even need the same MAH if putting in series....just C rating and you can be fine. Yes there are differences in each pack but as long as you do not drain them or run them a long time it is fine. I do not like to do this but for a quick test it would be fine.
        www.rcraceboat.com
        jwohlt5362@yahoo.com
        • RCprince
          • Jul 2007
          • 1684
          #109
          I've watched your channel before jeff, with AquaPalooza
          • Jeff Wohlt
            • 2740
            #110
            Watch the Lake of the Ozark one with me and my ad agency girls :) Rimante is from Romania and I just like to hear her talk!
            www.rcraceboat.com
            • Jeff Wohlt
              • 2740
              #111
              That other video is how it should run with 3 or 4S
              I am trying to get him to use my Y-harnesses and plug up 4S per side.
              www.rcraceboat.com
              • bustitup
                • 3072
                #112
                Sure Jeff and you can run regular Gas in a top fuel dragster but whats the point?
                I was trying to teach people that dont know....... that its not cool to mix brands and c ratings of lipos in brushless setups
                like the guy who had the "we are all pro's" comment
                there is a reason Jeff doent like to do it but yes it can be done
                  • 9481
                  #113
                  am I missing something
                  I thought this was a FE site not nitro?
                  • Rumdog
                    • 6667
                    #114
                    I wanna see a good vid of it on 3s. ASAP!! Before I build a cat that is. I'm more concerned with how it will corner.
                    • Jeff Wohlt
                      • 2740
                      #115
                      ...the same reason I said C rating has to be the same. You were just stating something that was not totally true...brand names do not need to be the same.
                      Yes, some cells are better than others. The only point was for a couple test runs it is perfectly fine. People have some impression that there is some voodoo in lipo cells. Not true. With good setups you should never be pulling more than 70% of the amps the pack is rated for. I would not put a 2500 25 C pack with a PQ 6000 25c pack if I know I was going to pull 125 amps constantly. You would be stressing the 2500 pack.
                      I would agree and practice the same ideals. Better to have your cells in correct combos.
                      I did not know everything we posted was for teaching others all the time. Some real world has to be in there.
                      www.rcraceboat.com
                      • lomdel
                        • 722
                        #116
                        Are we going to see your cat on 3S or 4S sometime? This really look like a beautifull boat. I would just find a way of getting rid of those two silicone water lines to enhance its scale appearance. Maybe some sponson mounted pick-ups?
                        • RCprince
                          • Jul 2007
                          • 1684
                          #117
                          http://www.offshoreelectrics.com/pro...?prod=gnd-4191
                          • Jeff Wohlt
                            • 2740
                            #118
                            Probably one of the things I would change. They kind of take the scale look out. It also has a water p/u rudder but they have put a set screw in the hole at the top. A person could take that out and have a third water intake. I worry about the water intakes as they are not too good and especially if it were run at top speed. Either they will drag...no good...or they are only catching spray.
                            Yep...in the hull would be sweet.
                            That was not my boat and the dude is on vacation until Friday and I leave then but I think he already has packs coming for it. 2S was a joke but I have to say for the weight of the boat and size I was actually shocked it ran out like it did.
                            4s and this boat will rock. I do not see why it would not handle like a good german hull as it is virtually the same hull design from what I could see. Pretty shallow sponsons and not a large mass of air entering in the front so I think it will take some serious speed. Most people that ordered this boat are getting them in. I expect in the next week we will see a bunch of youtube videos.
                            www.rcraceboat.com
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              #119
                              My shipment of them arrives today. I have 2 coming in, both for sale.
                              Whats infront of the motors? The black part? Looks like a gear box.
                              Steven Vaccaro
                              • Jeff Wohlt
                                • 2740
                                #120
                                Nope...ESCs rated each at 60 amps and water cooled. You are going to be inpressed. Slicker than snot man.
                                www.rcraceboat.com
