King Of Shaves C1 Brushless!
  • thrashmetal
    • 86
    #151
    king of shaves onboard cam
    love this video .
    this new kos looks like a really nice boat and i think it will really move one dual 4s lipos.
    the venom guys tried one on 8s and it was flying. they had no issues running 8s on it so far.
    hydro & marine step 4 mono neu 1527 1y 6s
    blackjack brushless 26 bone stock 6s 55.4 mph
    ballistic racing team
    • NitroVal
      • Jun 2009
      • 423
      #152
      Originally posted by thrashmetal View Post
      love this video .
      I somehow highly doubt that seeing as how:
      A. The esc is only rated at 60 amps and 6S
      B. The 2850kv motors would fly apart with that much power
      C. One full throttle run with that power would turn it in a floating bomb
      The RTR Nightmare- Electric King of Shaves
      Now with 540s- 62mph
      New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
      • Eggy
        • Jun 2009
        • 152
        #153
        If you dont belive it check out the video, it's on youtube.
        • NitroVal
          • Jun 2009
          • 423
          #154
          Im gonna need a link cuz I dont see it
          • hebner
            • 655
            #155
            That would be one 4s pack for each motor not 8s.
            • NitroVal
              • Jun 2009
              • 423
              #156
              Thats all I could think that they are being mistaken by. This boat has dual motors and ESCs, so it requires two packs.
              • 6S HYDRO
                • 1325
                #157
                2 4s packs- its not 8s and never states 8s.
                  • 9481
                  #158
                  love this video .
                  The video shows the cat running on 4s packs..
                  • Simon.O.
                    • 1611
                    #159
                    You are correct
                    Rough estimates give the following figures with 8S power
                    140A per motor
                    3500W per motor
                    90+ mph based on 69000 rpm.
                    Now back to reality
                    I can tell you that a 31mm non-metal prop will blow at 40000 rpm (estimated)
                    A 380 fed with 3500W of power will cook a steak........well, if it survives.
                    I need not go on as it is clear that this hull will will run well on 4S PER motor
                    and not 8S as some may read.
                    If you really want proof then buy one and hook up 8S per side and see what happens.
                    It is not me you need to shout at when it all goes up in smoke.
                    Re-read the whole story and make some informed decisions.
                    I like the idea and proof that 380's can make a Cat this size rock.
                    It gives me a lot to work with.
                    Well done Venom !!
                    • Eggy
                      • Jun 2009
                      • 152
                      #160
                      Just so its clear the video says Dual 4S, thats 4S PER motor.
                      From my calculations that is just over 43.000RPM UNLOADED with fully charged packs. No way that the motors will get those numbers when under load.
                      I agree that trying to go 8S PER motor is not going to work.
                      • NitroVal
                        • Jun 2009
                        • 423
                        #161
                        A 4S will spin that motor unloaded at 42180rpm. Using OSE's calculator, I entered an 80% efficiency and 20% drag. This puts the motor right at 33744rpm loaded and a top speed of 42mph. I can vouch that this calculator is pretty accurate as with 3S batteries, it says top speed is 32mph, which I measured 31.3 on GPS..
                          • 9481
                          #162
                          Anyone tried 4s yet with a gps?
                          • NitroVal
                            • Jun 2009
                            • 423
                            #163
                            I just got back from the lake to try my prop mods. I filed down all the casting flash left over from the factory and polished the props in a tumbler last night. It seemed to have worked. New top speed was measured at 35.0mph in the same conditions (less wind) on 3S. I think there may be more left in it with some ESC programming (max out the timing perhaps?) and maybe some prop angle adjustments to reach that elusive claimed 40mph out of the box number.
                            • Rumdog
                              • 6667
                              #164
                              The FE calc does not factor in twin motors or hull size. Twin motors matters a lot. having twins allows the motors to work more efficiently because there is less load on each one. Plus it has twice the propulsion.
                              • NitroVal
                                • Jun 2009
                                • 423
                                #165
                                I can agree to that. However I think the top speed wont be that far off versus a single motor. What the dual motor makes up for in power, it suffers in weight and drag, and vice versa for a single motor. Acceleration would definitely be quicker having dual motors.
