King Of Shaves C1 Brushless!
  • NitroVal
    • Jun 2009
    • 423
    #136
    No just single, but i'd imagine its not far off.
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
    • 6S HYDRO
      • 1325
      #137
      No it would be totally off.
      • NitroVal
        • Jun 2009
        • 423
        #138
        How so?
        • 6S HYDRO
          • 1325
          #139
          Its double the thrust
          • RCprince
            • Jul 2007
            • 1684
            #140
            wondering if the Neu 1115:1.5D (3500kv) or the 1y(2800kv) or a 2d(2600kv) would be a good upgrade?
            Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
            • NitroVal
              • Jun 2009
              • 423
              #141
              But it still would not affect top end. Even with twice the power, if both motors are spinning the same RPM and the same prop, the calculations should be similar. To test this theory, I finally was able to run mine today. With 4000mah 3S LiPos it did a top speed of 31.3mph in a light chop. I'll post videos when I get them edited.
              • NitroVal
                • Jun 2009
                • 423
                #142
                I dont think any of the Neu's would work. These motors are 380 size and most of the Neu's are 540 or bigger. I just ordered new mounts from OSE and when I've had my fun with the box stock, I'll throw them in along with a pair of Castle 5700's I have lying around (for now) and run it on the 3S. Should be interesting..
                • NitroVal
                  • Jun 2009
                  • 423
                  #143
                  Ok, heres an onboard ride with the EKOS I did today.. This boat handles like its on rails, except when you have a top heavy camera mounted on the deck, which is why the turns are a little slow. This was the first time it saw water, and I am very impressed. My only complaint (which may be driver error) is the steering servo seems pretty week. It had a hard time returning to center after a turn.
                  • RCprince
                    • Jul 2007
                    • 1684
                    #144
                    The 1100 neu's are 380 size 28mm x 65mm the 1115
                      • 9481
                      #145
                      You will let out the majic smoke!!
                      • NitroVal
                        • Jun 2009
                        • 423
                        #146
                        Oh ok, thats good to know. I was going strictly off what I saw on OSE's motor page.
                        • Tunda
                          Eh no steal my slipa
                          • 844
                          #147
                          I think you need to hold it wide open alittle longer and you should get more speed........
                          Hawaiian Tunda
                          • Rumdog
                            • 6667
                            #148
                            Sweet vid man! Seems faster than 31 mph. Was it wide open as Tunda says?
                            • NitroVal
                              • Jun 2009
                              • 423
                              #149
                              Yea, when I was measuring the speed, I didnt have the camera on and it was WOT. I was in a little cove, so I didnt have a whole lot of running room, but I think the boat had enough power to get up to full speed pretty quickly. There was a light chop, but the boat was staying glued to the water pretty well
                                • 9481
                                #150
                                I like the rear rooster shot!
