its just a sheet of paper with the beeps and tones decoded right?
EKOS clone and upgrade questions.
LVC- Low Voltage Cutoff, part of the ESC software, See Attached.Attached FilesFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
I would try turning the lvc off and see if you can run it for 5-minutes. Also, when you charge the packs, does you're charger show how much mah you're putting back into the packs? That would let you know if you're using the whole charge in your packs. Is it a peak charger??. the lvc could be set on its highest setting too, that would allow the lvc to kick in early.
the charger seems pretty nice for what it cost ($60). it has a temp sensor and even a port to hook to your PC and run software to monitor the packs, individual cell voltage, and see the overall voltage and mAh, current and few other things. you can charge /balance/ discharge ac or dc inputs.
SkyCharger B6AC+Land, Sea & Air, A true RC Addict.
THIS is a programming card for a Turnigy Marine, Hobbywing, Venom esc. Like Forescott said some of the esc's are the same just re-branded like the Venom ekos esc's & the Turnigy Marine series esc's are different labeled Hobbywing Seaking esc's. Venom & HK don't make the own stuff just change the label
Exactly.I think yours are the same as Turnigy,Hobbywing/seaking...etc.I have an extra you can have if you dont have one.
Yeah, that's a HOTA charger, a good one. I have two of them, modeled as Thunder Power from hobbypartz.Originally posted by JPriami View Postthe charger seems pretty nice for what it cost ($60). it has a temp sensor and even a port to hook to your PC and run software to monitor the packs, individual cell voltage, and see the overall voltage and mAh, current and few other things. you can charge /balance/ discharge ac or dc inputs.
SkyCharger B6AC+FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
