EKOS clone and upgrade questions.
  • JPriami
    N4FOX
    • 1711
    #76
    its just a sheet of paper with the beeps and tones decoded right?
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3416
      #77
      Its too easy to get it wrong using the beeps and throttle trigger pulls.You need a card.
      • JPriami
        N4FOX
        • 1711
        #78
        I can scan mine and post if you want to look at it. btw i just noticed the 4s cutoff is 12v and thats where my packs sit when i bring the boat back in. i bet the programming paper is wrong for this
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          #79
          LVC- Low Voltage Cutoff, part of the ESC software, See Attached.
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            #80
            Yep, a hobbywing card.
            • JPriami
              N4FOX
              • 1711
              #81
              ill look in a few mins thanks.. taking care of my 1yr old son..he trying to help type
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3416
                #82
                Good boy!Raise em right!
                • forescott
                  Hopelessly Addicted to RC
                  • 3009
                  #83
                  I would try turning the lvc off and see if you can run it for 5-minutes. Also, when you charge the packs, does you're charger show how much mah you're putting back into the packs? That would let you know if you're using the whole charge in your packs. Is it a peak charger??. the lvc could be set on its highest setting too, that would allow the lvc to kick in early.
                  • JPriami
                    N4FOX
                    • 1711
                    #84
                    the charger seems pretty nice for what it cost ($60). it has a temp sensor and even a port to hook to your PC and run software to monitor the packs, individual cell voltage, and see the overall voltage and mAh, current and few other things. you can charge /balance/ discharge ac or dc inputs.
                    SkyCharger B6AC+
                    • JPriami
                      N4FOX
                      • 1711
                      #85
                      im new to FE boats and all. whats a programming card lol
                      • forescott
                        • 3009
                        #86
                        Some speed controls sell a little programming box you can plug into the speed control to adjust the settings easily. Some of the import esc's are the same, just re-branded and can use the same programmer.
                        • JPriami
                          N4FOX
                          • 1711
                          #87
                          These are the ESC's in it
                          ESC's are 70 amp
                          Specs:
                          Type - Water Cooled
                          Voltage - 7.4 - 22.2v (2 - 6 cells lipo)
                          BEC - 5.5v @ 4 amp
                          Battery Connector - T-Style
                          • Diesel6401
                            Memento Vivere
                            • 4391
                            #88
                            THIS is a programming card for a Turnigy Marine, Hobbywing, Venom esc. Like Forescott said some of the esc's are the same just re-branded like the Venom ekos esc's & the Turnigy Marine series esc's are different labeled Hobbywing Seaking esc's. Venom & HK don't make the own stuff just change the label
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • LarrysDrifter
                              Big Booty Daddy
                              • May 2010
                              • 3416
                              #89
                              Exactly.I think yours are the same as Turnigy,Hobbywing/seaking...etc.I have an extra you can have if you dont have one.
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3784
                                #90
                                SkyCharger B6AC+
                                Yeah, that's a HOTA charger, a good one. I have two of them, modeled as Thunder Power from hobbypartz.
