EKOS clone and upgrade questions.
  • JPriami
    N4FOX
    • 1711
    #91
    Hota?
    • JPriami
      N4FOX
      • 1711
      #92
      I just wanted to say thanks for everyones help tonight. I like to learn about the stuff I am messing with as much as I can and all of you have been a big help since Ive come here. Thanks
      • Diesel6401
        Memento Vivere
        • 4391
        #93
        Prime example Venom 60 amp, Turnigy Marine 60amp, Hobbywing Seaking 60amp. These are all the EXACT same esc's with different labels. Notice the venom inflation
        - Diesel's Youtube
        - Diesel's Fleet
        • JPriami
          N4FOX
          • 1711
          #94
          I did notice that when looking at them all. I just wondered cause mines the 70amp and can run up to 6s if the card would work for it. but if it works with the 120amp esc and down to the 60 amp esc i guess im good being in between
          • forescott
            Hopelessly Addicted to RC
            • 3009
            #95
            That does NOT look like a seahing/turnigy esc to me. water cooling is completely different.
            • JPriami
              N4FOX
              • 1711
              #96
              says DHP on the label? nevermind i dunno wtf that is for sure lol
              • JPriami
                N4FOX
                • 1711
                #97
                here is the sheet it came with for programming
                it does say DHP speed controller programming instructions
                • forescott
                  • 3009
                  #98
                  I cant find any info on the web for this esc?? Anyone else??
                  • JPriami
                    N4FOX
                    • 1711
                    #99
                    me either. not for programming sheets.
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      #100
                      I take it your refereing to his 70 amp esc, which you are correct that does not look like a seaking. I don't think seaking makes a 70amp esc. I have NO clue WTF that is
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3416
                        #101
                        My guess its the same esc as the rest.Maybe it just has a different cooling plate?
                        • forescott
                          • 3009
                          #102
                          Wow! That is complicated. I would read it a couple of times and reset your esc's. Do you set both at the same time or one at a time. I know the ekos sets them both at the same time, but sometimes the esc's dont beep at exactly the same time and it gets really distracting. I disconnect the y-harness and set them individually on mine.
                          • JPriami
                            N4FOX
                            • 1711
                            #103
                            I should mention the water cooling lines are not like the one in the pic. the sticker is the same. but the cooling lines are run diffrently. they go in and out the same side. and its on the opposite side of the capacitors
                            • LarrysDrifter
                              Big Booty Daddy
                              • 3416
                              #104
                              Do you still have any boat hot rodding funds left?If so,buy two 120 amp esc's and you ll be covered for just about any motor you put in later.Hobbyhot.com sells the SeaKing 120 cheaper with the programming card than with out.
                              • JPriami
                                N4FOX
                                • 1711
                                #105
                                I set one at a time to make sure i am only hearing one speed controller beeping
