The Voracity tuning thread
    • 9481
    #571
    Great job !
    • Banzee
      • Mar 2012
      • 189
      #572
      Great job !
      Thank's ! Need to work on the cg cuz i wasn't WOT !
      • Keagan-Z06
        • Mar 2016
        • 970
        #573
        Can anyone confirm if the abc 1914 or 1915 props are ok to be considered an all around prop? Or just for 1-2 high speed passes on stock electronics?
        Thanks!
          You should be ok with the 1914
          • Keagan-Z06
            • Mar 2016
            • 970
            #575
            Thanks Travis.
            • paulfromtulsa
              • Nov 2013
              • 211
              #576
              I run 1915 on my voracity and temps never get hot
              • Keagan-Z06
                • Mar 2016
                • 970
                #577
                Nice! I have a 1915 as well but will work my way up. Still sorting out some balance issues.
                • rcboone2000
                  • 83
                  #578
                  I don't post on here much but if u run real loose I'm running a 2215 still stock motor with a 180 amp speed control and on speed runs I have hit 74 mph I do 2 speed runs then some slow runs to cool the hottest I've seen motor Temps is 115 degrees I have two water pickups
                  • Keagan-Z06
                    • Mar 2016
                    • 970
                    #579
                    Nice! Don't have the cojones to run at those speeds with the V.
                    • rcboone2000
                      • 83
                      #580
                      I like the voracity better than both of the zeLos with the 36 every time I get close to 70 mph it goes air borne can't keep the 48 up rite I got tired of fixing them so they are on the shelf
                      • Keagan-Z06
                        • Mar 2016
                        • 970
                        #581
                        I hear u. My Z has been a bad boy but my favorite so far has been the Geico. Fast n stable!
                        • morrasen
                          • Mar 2016
                          • 1
                          #582
                          The ABC 1815 is a 1815-17-45?
                          and the 1915 is a 1915-17-45?
                          • Keagan-Z06
                            • Mar 2016
                            • 970
                            #583
                            I believe those are correct morrasen. I can talk for the 1915 as I have one.
                            • LuckY07
                              • 56
                              #584
                              I just bought a stock Voracity and was thinking about buying the ABC 1914 to start (then work up to the 1915). Would this be a good starting point for the first mod? I noticed they were sold out on here, does anyone know how often then restock them?
                              Is it recommended to S&B the stock prop?
                              Where can I buy a prop balance (or should I be looking at buying one that's already S&B)? Thanks.
                              • LuckY07
                                • 56
                                #585
                                what tools are you using to S&B them?
