***NEW**** Pro Boat Voracity 36" Mono!!
  • arrover
    • May 2015
    • 322
    #271
    Thanks! I'm glad you like it. I really haven't seen the need to put in more vertical supports. I even sometimes set the Voracity crosswise across the top of the bag when I'm working on it and the top pipes bow a little but really not bad. I haven't seen the need to glue any of my joints so if you feel like you need to add more stuff later it would be easy. EDIT: If you think people might stack things on top of the boat bag, I would add a vertical support in the middle.
    ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
    • Xtreme Thunder
      • Jan 2014
      • 34
      #272
      I really enjoyed watching the DIY on that boat bag, ... going to definitely look into making one!
      Thanks!
      • paulfromtulsa
        • Nov 2013
        • 211
        #273
        Does anybody here have water coming into the hull from where the trim tabs bolt up? How can I stop that? iThought about silicon but have no idea how to get it in between the outside of the hull and the screw
        • montymike
          • 786
          #274
          Thinking you have already checked screws for tight. I have used liquid thread seal permatex.
          • arrover
            • May 2015
            • 322
            #275
            Yes I have the same issue. I haven't done anything about it yet but I need to. Let us know what works for you.
            • paulfromtulsa
              • Nov 2013
              • 211
              #276
              Yes in tightened all the screws but water still seeped in pretty bad still. Is the thread seal permatex pretty thick? Cause the screw hole is is big so I'm not sure if the permatex will just ooze off. Thanks
              • montymike
                • 786
                #277
                No goes on like thread locker but little thicker . Let dry screw in. My main use for it was for sealing 350 chev. Head bolts. Has Teflon in it.
                • montymike
                  • 786
                  #278
                  A dot of silicone. On the inside of hull on each nut could not hurt. Guess got lucky mine does not leak. I use wood fondue sticks (take point off) to apply.
                  • arrover
                    • May 2015
                    • 322
                    #279
                    That's funny. I use wood fondue sticks for glue projects too. They work well.
                    • paulfromtulsa
                      • Nov 2013
                      • 211
                      #280
                      What is no goes? Do you have a link to the product? Thanks
                      • montymike
                        • 786
                        #281
                        A good auto parts store. I were I got mine
                        • montymike
                          • 786
                          #282
                          Permatex 14h thread sealer with teflon sorry was at work.
                          • paulfromtulsa
                            • Nov 2013
                            • 211
                            #283
                            Just put some of that permatex on it just now. Will let you guys know the results when it dries
                            • paulfromtulsa
                              • Nov 2013
                              • 211
                              #284
                              The permatex worked great no more water in the hull
                              • Xtreme Thunder
                                • Jan 2014
                                • 34
                                #285
                                Finally got time to actually put batteries in mine to set up in the Living Room.
                                Is it normal for the steering servo to release a pretty loud audible hum/ buzz? I turn the transmitter on, then the esc switch and I get the hum/ buzz, however, it will go away as soon as I call for steering and doesn't come back until I power down and begin to re-power up. I made sure it was the steering servo by disconnecting at the receiver and powering up and does not make such noise when disconnected. Thoughts?
                                I should be putting it in the water today!
