***NEW**** Pro Boat Voracity 36" Mono!!
  • hobby_man
    • Sep 2011
    • 125
    #241
    I thinned and polished the prop some, I re routed the water lines so the water comes out of the top of the motor and then out the boat. I made the loop on the left side of the ESC larger.
    I use pro boat Grease, I have tried others and they are not the same, someone asked that.
    I just finished a 4 minute full throttle run in choppy water with the boat running tight.
    Love this boat, grease, charge and go!
    the bulk head fitting for the water line IN came out,,I think it was glued in with CA, will re glue with silicone
      Got mine!!!
      • Xtreme Thunder
        • Jan 2014
        • 34
        #243
        Thanks for the reply, figured I'd ask the seasoned hobbyists!
        I can't wait to run mine! This boat is perfect size and proportions, and any angle this boat just looks boss!
        • montymike
          • 786
          #244
          Got mine!!!
          Let us know if this thing likes a x645 or a m645 and setup thanks mine is on its way should be here by weakened.
          • paulfromtulsa
            • Nov 2013
            • 211
            #245
            i think im going to try the prather 230 prop what do you guys think?
            • montymike
              • 786
              #246
              A Prather 225 not a 230 without changiing Speedo a 230 to much prop would draw to much amps put that spedo in amp protection mode.
              • paulfromtulsa
                • Nov 2013
                • 211
                #247
                What do you mean by without changing speedo? Is that an esc? I have already upgraded to a 180amp esc.
                • montymike
                  • 786
                  #248
                  Ya should be good then.
                  • shua
                    • Apr 2015
                    • 479
                    #249
                    Yes. You are correct.... Speedo = ESC
                    EDIT.. Montymike beat me to it! lol
                    • paulfromtulsa
                      • Nov 2013
                      • 211
                      #250
                      Do you think a 235 would be too much? I want to max out the the boat
                      • montymike
                        • 786
                        #251
                        Thinking if u put that if you put that big of prop that motor would get hot.bigger motor connectors and bigger battery connectors 40x92 motor .
                        • montymike
                          • 786
                          #252
                          Looks like everyone wants mod this boat , like we always do... L.O.L.
                          • Tamelesstgr
                            • Jun 2014
                            • 1512
                            #253
                            Leave something stock? What fun is that?
                            NEVER SATISFIED RACING
                            Fine Design 32 V-Hull 4082+6s
                            • montymike
                              • 786
                              #254
                              Perhaps not "bigger", but bigger isn't always better. More efficient is what you are looking for... Sharp and thin would be a great starting point...
                              Think when I get mine will do this he knows.... Won't throw of the ballance of the boat
                                Prather props have always proved the slowest out of any props I've tried except plastic. I'd stick with octura and abc. Get a abc 1815-17-45 and I bet it's faster than the stock prop by at least 5mph. I've pulled less amps on this prop than a m645 but who knows how it will react on this boat. If you wait till this weekend I will have tested a few different props on it and I should be able to get video on it.
