***NEW**** Pro Boat Voracity 36" Mono!!
  • T.S.Davis
    • 6266
    #121
    Picture a 40 minute Q-Offshore heat!
    Not the way I drive. My throttle finger is cramping up just thinking about the ocean like conditions.
    Raff, those numbers are reasonable with quality equipment. If we try to run those temps on what we think of as "spec" you get failures.
    My Q sport comes in at 138 every run.
    Noisy person
    • bigcam406
      • 236
      #122
      any idea what the temps and run times would be on 4s? i remember Darin stating that it was running at approx 40mph on 4s.i myself dont really have experience at 50mph,so i would like to crawl before i walk so to speak.with 4s,could you prop up or would that even be necessary? just wondering,as im starting to like this boat more as more info is given.thanks in advance.
      • Rafael_Lopez
        • Jan 2015
        • 470
        #123
        I had one tester that specifically tested on 4s. Below is one of his runs. His runs vary +/- 5*, or so. As you can see, the increase of voltage really heats up the connectors. ESC and motor temps stay pretty constant regardless of voltage.
        Run Time (min/sec) 4:25
        Battery Temp (°F) 138
        Bat Plug Temp (°F) 145
        Motor Temp (°F) 130
        Motor Plug Temp (°F) 136
        ESC Temp (°F) 129
        Steering Servo Temp (°F) 88
        Rafael Lopez
        Product Developer-Pro Boat
        • bigcam406
          • 236
          #124
          thanks for the quick reply.judging by what you provided,the only thing that i should be concerned about is the connector temperature.is 50c the minimum discharge rate that we should be using,even on 4s?
          • Rafael_Lopez
            • Jan 2015
            • 470
            #125
            Yes, we recommend 2, DYNB3810EC for 4s.
            Rafael Lopez
            • bigcam406
              • 236
              #126
              thanks for the info.much appreciated.
                • 9481
                #127
                I wonder how two 6s 3300mah packs in parallel would do in this boat ?
                • shua
                  • Apr 2015
                  • 479
                  #128
                  I'm wondering the same thing. I have similar matching pairs of 6s packs from my Helis.
                  • skeeler
                    • Jul 2007
                    • 208
                    #129
                    So, it must be safe to assume a 36-inch twin cat is on the way, right?
                    Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
                    '09 Miata.
                    Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
                    • skeeler
                      • Jul 2007
                      • 208
                      #130
                      By the way, should ProBoat offer a 36-inch cat, I'd love to see it in either the Blackjack or Geico livery, rather than Rockstar livery.
                      Back on topic: Thanks for bringing the Voracity 36 to market. It looks like a good product, and I'm very interested.
                      '09 Miata.
                      • T.S.Davis
                        • 6266
                        #131
                        Back off topic. haha
                        A 36" Geico would be a riot.
                        Noisy person
                        • Xtreme Thunder
                          • Jan 2014
                          • 34
                          #132
                          Rafael,
                          Is Horizon (Pro Boat) still on schedule with anticipated physical stock with the time-line mentioned a few pages back?
                          Regards,
                          Joe
                          • Rafael_Lopez
                            • Jan 2015
                            • 470
                            #133
                            Yes.
                            Any delays will be announced through our website and I'll make sure to let you all know.
                            Rafael Lopez
                            • Xtreme Thunder
                              • Jan 2014
                              • 34
                              #134
                              Thanks.
                              I did notice that the Pro Boat website indicates Late August.
                                • 9481
                                #135
                                Agreed !
