ProBoat's new 29" Mystic Brushless catamaran
  • Derrick Davis
    • 108
    #181
    ecovert,
    Would you mind taking a couple pictures of your project? I'm interested to see it. Thanks.
    They call me DOUBLE D
    • desmobob
      • Sep 2011
      • 172
      #182
      Originally posted by ecoovert View Post
      The only problem is finding a way to drill with onlyabout 1/4" to get the drill in. You see the bulkhead sets only about 1/2" above the hull and I would have to drill into the side of the bulkhead. I might have to drill in at an angle or better yet borrow my dads Dremmel and finish the job with a jewlwers file.
      I'm guessing it would be easiest to "grind" the hole with a large burr bit on a Dremel rather than drill it. Although I do have a set of short twist drills with knurled knobs on the end that are made to be used by hand (from Tower Hobbies) that would likely work. You can probably even lay a regular old X-acto knife down in the hull and twirl it like a drill... the point of the blade will quickly go through the plywood bulkhead.
      Good luck and keep us posted,
      desmobob
      PS - I have the Craftsman mini-wrenches too. I got them on eBay for cheap and they're handy!
      • ecoovert
        • Aug 2011
        • 275
        #183
        Sure, I would like to but lately having just moved all the way across the country I still havn't located my laptop. It has the software I like to use for uploading photos; my work computer which I'm using here does not. I hope someday someone in the family unpacks a box with my laptop in it. I also used it to edit videos for youtube.
        • ecoovert
          • Aug 2011
          • 275
          #184
          Thanks for your input. As it stands right now I put some Superglue on the screw and screwed it in pushing extra hard on the screw as I screwed it in. I wish I had waited for all the ideas you guys brought forth. If what I did doesn't hold I'll use one of your methods. You are right about those little Craftsman mini wrenches.
          • roadrashracing
            • 1630
            #185
            Someone had one of these at the pond today, his had a plastic hatch, is this what they came with or is it something they changed?
            • tiqueman
              • Jul 2009
              • 5866
              #186
              That's what they come with
              • ecoovert
                • Aug 2011
                • 275
                #187
                If your talking about the plastic hatch with the see trough windo, yes that's what they come with.
                • ecoovert
                  • Aug 2011
                  • 275
                  #188
                  Here you go. I finally got some pictures with my camera and found that I was able to install them on my work computer.Miss Geico project 002.jpgMiss Geico project 010.jpgMiss Geico project 006.jpgMiss Geico project 012.jpgMiss Geico project 014.jpg
                  • ecoovert
                    • Aug 2011
                    • 275
                    #189
                    In case some of you would like to see my home made offset rudder bracket from another angle here it is. This simple setup works great. No more porpoising and it only cost maybe a couple of dollars to build. I must say I already had some 1/8" aluminum on hand.
                    Miss Geico project 019.jpgMiss Geico project 016.jpgMiss Geico project 015.jpgMiss Geico project 014.jpgMiss Geico project 013.jpg
                    • d.a.v.e
                      • Jan 2011
                      • 230
                      #190
                      What motor is that?
                      • ecoovert
                        • Aug 2011
                        • 275
                        #191
                        It's a Nemesis Gold 4082 in 2200kv configuration. Same thing as a Leopard 4082. This motor is rated at 4.66 horse power. Ofshore Electrics sells the Leopard version and Fine Design RC sells the gold version but Chris at finedesignrc.com sells his with the water jacket included. The water jackets run between $17 and $25 depending on where you get them. Chris sells the complete motor/water jacket package for $119.95. He also is great at talking you through your upgrades.
                        • d.a.v.e
                          • Jan 2011
                          • 230
                          #192
                          What kind of speed are you seeing out of this with that monster in it? Did he sell you the added motor mount it looks like you have as well?
                          • ecoovert
                            • Aug 2011
                            • 275
                            #193
                            Yes Chris sold me the package deal. That saved me about $10 as I would have paid about $17 for the jacket plus $110-$120 for the motor. The only thing that I considered was going ahead and ordering the Leopard jacket seperate as it would have added contrast as they are red. I think red and gold would have looked good together. But I did save money this way so I'm ok with that. I was getting about 65 out of my 4074 motor. With this motor adding another 1.4 horsepower I should be seeing around 80 depending on prop selection. With my x442 prop I should get mid 70s but if I were to install my x645 prop, well who knows.
                            • Derrick Davis
                              • 108
                              #194
                              Nicely done....thanks for putting up the pictures!
                              • ecoovert
                                • Aug 2011
                                • 275
                                #195
                                Thanks Derric: smile:
