Anyone seen this before : http://www.horizonhobby.com/Products...ProdID=PRB4075 ? Looks like Darin is a busy man!
ProBoat's new 29" Mystic Brushless catamaran
FINALLY!!! Cat's out of the bag!!Originally posted by lomdel View PostAnyone seen this before : http://www.horizonhobby.com/Products...ProdID=PRB4075 ? Looks like Darin is a busy man!
This is the same basic hull as the Miss Geico, but with some revised hardware, a different motor/ESC., and some other little details. It's been in works for quite a while (Since about the minute the Miss Geico actually hit the market! ) We wanted something that the racer and Sport driver could customize better (white base paint, minimal decals), and thought it was a good opportunity to have something a little hotter in the motor/ESC department.
Should be a nice addition to the lineup.
My personal early sample is actually all race-prepped, and on it's way to Ken Haines right now (mailed it yesterday). Ken will be racing it at the FE Nationals in Offshore... Here are a shot of the hardware setup.Attached FilesDarin E. Jordan - Renton, WA
Here is the promotional video from the ProBoat site:
I wish the RTR's would get away from paint and use gelcoat. Much more durable in my opinion. Cost difference is almost null considering the extra prep that paint requires.
Looks like a great boat though! Ken's gonna kill us in LSO! Yikes!
Originally posted by Darin Jordan View PostIt's white paint. Same finish that all the other RTR boats in the lineup have.Mini Cat Racing USA
www.minicatracingusa.com
Looks like a great boat! I may have to pick one up in june. Its not too steep of a price either which is good.
Makes sense now. HYDROJERRY just mentioned yesterday I think that he ordered a new "Geico" and it was said that its coming w/ the offset rudder.
Very nice Darin. Glad to see you worked at it and also listened to what "we the people" had to say about it.
Any chance you got PB to do anything about the little wires on the motor yet? I ran mine in LSO last weekend using a detongued 642, 1800KV PB motor and a 120A speedy and it ran pretty darn hot compared to its same speed using the M445 and 1500 motor. Any thoughts? I checked all the obvious, drive line binding etc and everything seemed fine. What prop might you recommend for the 1800 set up? or is that not public yet
I also sent you a PM regarding this and something else I think yesterday or the day b4.
You know, I'm not sure I do. I'll have to look at home.Originally posted by lomdel View PostAny shots of the inside Darin? What size flex-shaft is used?
The inside is simlar to the MG. They placed the steering servo a little differently, and the battery trays are extended aft, almost all the way back. I'm pretty sure they'll have full pictures up on the site in the coming days.
I didn't even know this was getting posted, which shows you how in the loop I am at times...
Oh, Flex is a .150... Should be the same shaft as the MG.Darin E. Jordan - Renton, WA
It's also going to be release in two versions... Plug and Play, and as a RTR. Plug and Play= you add your RX and supply the TX. Should address the needs better of all of those "Other" radio users... :D
Plug and Play will be released first. RTR will be coming out at a later time (later this year, I believe).Darin E. Jordan - Renton, WA
Base White, plug and play, nice hardware. Darin thanks for listening. I do not need another stupid radio.Originally posted by Darin Jordan View PostIt's also going to be release in two versions... Plug and Play, and as a RTR. Plug and Play= you add your RX and supply the TX. Should address the needs better of all of those "Other" radio users... :D
Now develop the perfect 30" Hydro
when will the plug and play be available Darren? Oh I see it now on Horizons Site... says late june... hopefully this will hold true...Originally posted by Darin Jordan View PostIt's also going to be release in two versions... Plug and Play, and as a RTR. Plug and Play= you add your RX and supply the TX. Should address the needs better of all of those "Other" radio users... :D
I can't make any promises, since this is WAY outside of my paygrade, but I WAS told that they were already packaged up in a container and were in the process of being shipped here, so we'll see.Originally posted by JMSCARD View Postwhen will the plug and play be available Darren? Oh I see it now on Horizons Site... says late june... hopefully this will hold true...Darin E. Jordan - Renton, WA
