"that" miss geico
    • 7651
    #181
    Originally posted by masonis1 View Post
    The picture two above was a hint... Powered by castle!!!!! oh yes. Ill swap the.motor.out during the winter when.I.can't.drive.anyway. So will this motor get hot with the prop I.have now on.4s?
    Sent from my SPH-D700 using Tapatalk 2
    You mean with out cooling?
    • masonis1
      If you cant control it 👍👍
      • 1173
      #182
      Without water cooling. I have a get sink that adds some to keep it cool but not mug
      When speed isnt the option, change your ways
      • masonis1
        • 1173
        #183
        Just pick some and we'll go from there.What is you're e-mail and I'll send you the PDF so you can have a better look.They are on white but can be trimmed any way one see's fit.
        Email is mmcgavock1096@yahoo.com
          • 7651
          #184
          I sent you the file. You should get a cooling can for the 1515.You have time if you're going to do this over winter.
          • masonis1
            • 1173
            #185
            i will look into a cooling can. ofe sell them?
            also, i found this...http://www.hobbyking.com/hobbyking/s..._5mtr_402.html
            402 is the checkered. would this work or do i want stickers
              • 7651
              #186
              That should work.I see some have had peeling problems but if you do all you're decals before clear you should be OK.
              • masonis1
                • 1173
                #187
                I did a very thin clear. Nothing hardly atball.
                Will the 1515 get warm without the.cooling?
                  • 7651
                  #188
                  Depends how long you run it.You could keep checking it and bear in mind that the rotor inside gets hotter quicker and it takes a while for that heat to "soak" out to where you can feel it.If you run it then and check the temp then let it sit for 3-4 mins it will be hotter.
                  • masonis1
                    • 1173
                    #189
                    Oh wow. I might test with.out.but I.will.getba can
                      • 7651
                      #190
                      Here is a link to what Alpha has http://forums.offshoreelectrics.com/...t=Alpha+spirit
                      • masonis1
                        • 1173
                        #191
                        Alright. Thanks. I didn't see prices
                        • masonis1
                          • 1173
                          #192
                          Looks great. Detongqued, balanced, sharpened, pitch.added on trailing edge, polished. Looks great. Im going to.charge the.batterys so.i.can test.before i leave for 3 weeks
                          • masonis1
                            • 1173
                            #193
                            Might go test tomorrow.
                              • 7651
                              #194
                              So that is a grim prop?Can you tell where it was cupped?
                              • masonis1
                                • 1173
                                #195
                                That is the grim prop. I dont understand what you mean cupped. I can tell where it starts to bend more where pitch was added on the.tips. The guy.did.a good job. Does it look alright for you?
