"that" miss geico
    Originally posted by masonis1 View Post
    The picture two above was a hint... Powered by castle!!!!! oh yes. Ill swap the.motor.out during the winter when.I.can't.drive.anyway. So will this motor get hot with the prop I.have now on.4s?
    Sent from my SPH-D700 using Tapatalk 2
    You mean with out cooling?
    • masonis1
      If you cant control it 👍👍
      • 1177
      #182
      Without water cooling. I have a get sink that adds some to keep it cool but not mug
      When speed isnt the option, change your ways
      • masonis1
        • 1177
        #183
        Just pick some and we'll go from there.What is you're e-mail and I'll send you the PDF so you can have a better look.They are on white but can be trimmed any way one see's fit.
        Email is mmcgavock1096@yahoo.com
          I sent you the file. You should get a cooling can for the 1515.You have time if you're going to do this over winter.
          • masonis1
            • 1177
            #185
            i will look into a cooling can. ofe sell them?
            also, i found this...http://www.hobbyking.com/hobbyking/s..._5mtr_402.html
            402 is the checkered. would this work or do i want stickers
              That should work.I see some have had peeling problems but if you do all you're decals before clear you should be OK.
              • masonis1
                • 1177
                #187
                I did a very thin clear. Nothing hardly atball.
                Will the 1515 get warm without the.cooling?
                  Depends how long you run it.You could keep checking it and bear in mind that the rotor inside gets hotter quicker and it takes a while for that heat to "soak" out to where you can feel it.If you run it then and check the temp then let it sit for 3-4 mins it will be hotter.
                  • masonis1
                    • 1177
                    #189
                    Oh wow. I might test with.out.but I.will.getba can
                      Here is a link to what Alpha has http://forums.offshoreelectrics.com/...t=Alpha+spirit
                      • masonis1
                        • 1177
                        #191
                        Alright. Thanks. I didn't see prices
                        • masonis1
                          • 1177
                          #192
                          Looks great. Detongqued, balanced, sharpened, pitch.added on trailing edge, polished. Looks great. Im going to.charge the.batterys so.i.can test.before i leave for 3 weeks
                          • masonis1
                            • 1177
                            #193
                            Might go test tomorrow.
                              So that is a grim prop?Can you tell where it was cupped?
                              • masonis1
                                • 1177
                                #195
                                That is the grim prop. I dont understand what you mean cupped. I can tell where it starts to bend more where pitch was added on the.tips. The guy.did.a good job. Does it look alright for you?
