Your MG that started off as a hull
    • 7651
    #766
    Originally posted by jasoncyclone
    I'm not sure about inline rudders. I don't have anything with an inline rudder.
    I don't like inline rudders,they ruin a perfectly good roostertail.
    That being said,I haven't figured out why my Df mono has such a obvious one and the Miss Behavin' does not.Props are close,645 on MB,646 on the DF.
    I gotta get some other boats named.
    • jasoncyclone
      • Jun 2011
      • 475
      #767
      What is your strut set at on your MG? I have a large rooster tail on mine.
      Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
      • macdon
        • Jun 2011
        • 970
        #768
        Hi Jason,
        It is not actually an in-line rudder setup perse, but rather the positioning and relationship of the prop and rudder. My apologies if my explanation above was a bit vague, permit me to explain better ...............
        Your boat is down on the floor and you are standing behind it - the prop is in the middle and the rudder is on the right side. Your strut is 2" long, so your prop is 2" away from the transom. You have a rudder with a 1" long bracket, if you install this your rudder will be 1" away from the transom. This is closer to your transom than the prop.
        Next is you have a rudder than has a 3" long bracket, if you install this your rudder will be 3" away from the transom so this would be further from the transom than your prop.
        So since the strut/prop has a constant measurement of 2" away from the transom - would there be any effects on running the boat if the rudder is closer (1") to the transom and ahead of the prop or 3" away from the transom and further back from the prop?
        Let me support what Im trying to say thru pics - they all have offset to the right rudders:
        First pic is of my yellow surge crusher catamaran having a rudder that is further from the transom than the prop
        Second pic is of my Bugatti concept deep vee boat with having the same distance of prop and rudder from the transom
        Third pic is of my Princess deep vee yacht having a rudder thats closer to the transom than the prop
        • tagasagwan
          Molino Boater!!!
          • 965
          #769
          I would be guessing Mac but, since it was mentioned that Cats turn better with the rudder close to the transom, and strut usually have short brackets, install your strut with 3/16 cable and do the adjustment with the rudder bracket to make the rudder blade stand beside the prop as seen on your 2nd photo. Then again, its just me! I could be wrong you know!
          My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
          MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.
            • 7651
            #770
            I'm not sure what effect having the rudder ahead of the prop would be,my first feeling is not that great.I would think it would then be fighting and hard on the servo and control.At speed anyway,slow may be different.Do you have brackets so you can adjust on hand?
            • macdon
              • Jun 2011
              • 970
              #771
              Of all my boats, only the HK Princess Yacht has the rudder ahead of the prop. Well, its not a high performance race boat anyway, so I guess thats fine. However, I might get a bit longer rudder bracket for it just to see any difference.
              I already ordered the rudder from ebay and got a 3/16" Strut with flex, struffing, etc. from Frank of Promise Hobby (ebay) for the 37" Cat so will check once they arrive.
              Nonetheless, the strut would be installed first and at worse I guess I could have a bracket extension made for the rudder if it comes out too forward.
              OT:
              I really enjoyed my Dumas F1 Tunnel last week that I decided to give it a bit of character. Just sharing pics..........
                • 4297
                #772
                You did a very nice job on that,
                I like the colors to, And what are the green marks ?
                If it were mine, I would add some red to the tips to.
                Like some jet fighter have.
                How fast does go and do you get much run time with it ?
                • macdon
                  • Jun 2011
                  • 970
                  #773
                  Thanks Lenny but its not my work. Its the work of a custom vinyl decal maker in a mall - just a small kiosk along the corridor. Its cut vinyl not printed, thus each color is cut and adhered in place. I did choose the design thou. I thought it would be something different apart from the usual paint.
                  They did tell me to bring the whole boat so they could design it better, but since I was doing some mods on the tunnel I just thought of bringing just the canopy.
                  I run this for the first time last Sunday - it was the first time for me to run a F1 Tunnel and also a first time for me to use an outboard setup. I really enjoyed my experienced thus I had new decals for it now. Here's a short video of the maiden last Sunday:
                  Edit: oh, those green marks are side mirrors which the decal maker added without telling me hahahahaha!
                  • jasoncyclone
                    • Jun 2011
                    • 475
                    #774
                    The F1 looks great Macdon. As far as the rudders go, you dont ever want the rudder in front of the prop. I always have it just behind the prop. looking from the side of the boat on cats.
                      • 4297
                      #775
                      Looks like running good in a little chop to.
                      Is that on 4s ?
                      • macdon
                        • Jun 2011
                        • 970
                        #776
                        Roger that Jason - thanks!
                        I already ordered both the rudder and the strut - so with the consideration of keeping the rudder close to the transom but still behind the prop, then the worse scenario for me is just having a short custom rudder bracket made by a machine shop. Not really a biggie, so I think Im good to go.
                        Here's a new question thou:
                        If a single battery pack could fit in the middle of the Cat with all considerations like cog, etc. done correctly - would you do it or still go with having 2 batteries - 1 per side?
                        • macdon
                          • Jun 2011
                          • 970
                          #777
                          Is that on 4s ?
                          Yes sir - just a single 5000mah 4s batt :)
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            #778
                            Seams funny to me, you would think the rudder being infront of the prop would be better cuz it would be in clean water instead of in the prop wash, but i dont no for sure and sorry for the late response Mac, you want the 3/16 stuff and my rudders are 110mm long from the top of the bade to the bottum,,, and yeah that tunnel hull looks sweet!!!!
                            • HYDROJERRY
                              • Jan 2010
                              • 2503
                              #779
                              one battery per side helps keep the hull level when running!!!
                              • macdon
                                • Jun 2011
                                • 970
                                #780
                                Thanks for the feedback Jerry - appreciate it bud!
                                Hmmm.........so 110mm (4-3/8") is enough for the 37" long Genesis? My 30" long MG is using a 115mm rudder.
                                Okay, thats food for thought. But since the custom 37" Cat is wider than the Genesis - maybe a longer rudder is needed? Maybe? Should be? Could be? hahahahaha!
                                Jason - I googled the word "sleep" - interesting concept, eh? hahahahaha!
