Your MG that started off as a hull
  • CHIEFY_44
    • Nov 2010
    • 254
    #1726
    Hi skyman,
    I run 4s2p 4000 mah on the 1515 with a m445 prop and it hits 55mph and runs good, no heat problems, and no I would not even think about 6 cells on this motor.
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
    • skyman
      • May 2012
      • 290
      #1727
      Ok, I won't :)
      Sent via Tapatalk
      Axial Yeti XL - Traxxas Slash 4x4 (x2) - Losi Mini 8ight - Tacon Soar Buggy - Blade 120SR - Miss Geico 29 (hull + parts)
      • jasoncyclone
        • Jun 2011
        • 475
        #1728
        Trust me Skyman, 4S will be FAST!!! Keeping it on the water is a challenge as you can see in the video link below...
        Anyone else want dibs on Mardons custom scoop hatch???? It looks really good!!!
        Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
        • HYDROJERRY
          • Jan 2010
          • 2503
          #1729
          ive been trying to keep up here but im lost again what hatch are we talking about??? i must have missed that post..not that i can buy it wright now so ill say ill pass but would still like to see it any pics..ps nice vid but i think you need a bigger boat,hehehe. to much azz for the little MG..
          • skyman
            • May 2012
            • 290
            #1730
            great vid jason! how did you retrieve the boat when it flipped? and where is that lake, i might want to take my boat out there as well? bay area?
            • jasoncyclone
              • Jun 2011
              • 475
              #1731
              Hey Ed, I was able to get the Geico back with a fishing pole.... I run my boats at Lake Mendocino. Its about 2 hours north of SanFran....
              • skyman
                • May 2012
                • 290
                #1732
                what are you hooking to to reel it in?
                • jasoncyclone
                  • Jun 2011
                  • 475
                  #1733
                  I use a tennis ball and drag the boat back in with it....
                  • skyman
                    • May 2012
                    • 290
                    #1734
                    i better prepare myself for my first run
                      • 7651
                      #1735
                      I made some changes to My MB that you's may find useful.First I tried a new prop,an ABC 1818 which has a diameter of 45mm and a pitch of 1.8 or 81mm.This vid also runs my now standard M645 which is 45mm and a pitch of 1.6 or 72mm.An M prop has the tongue removed.I also decided to raise the strut to 2.5mm above the ride pads in hopes of a little stability.It worked.But I think the boat is more fun to drive as it was. Here is the vid http://www.youtube.com/watch?v=22rwn...=youtube_gdata
                      It was taken over the weekend roadtrip.
                        • 7651
                        #1736
                        Did you check my new rescue rig setup Jason?It is in post 1670 go to the end to see the little guy.
                        Ah heck,maybe you missed it anyway http://www.youtube.com/watch?v=IO93a...=youtube_gdata
                        • jasoncyclone
                          • Jun 2011
                          • 475
                          #1737
                          I love the wheelies on your shocker!! They make me laugh hardcore!!! The geico runs pretty good..what were the temps with those props??
                          • skyman
                            • May 2012
                            • 290
                            #1738
                            alright guys, i wanna be able to create some videos too, so i need your help building this thing
                            given my parts listed in post #1719 what are your recommendations for the rest? i have no idea how to build this thing except for what stephen recommended to me.
                            what else do i need to make this build a success? only the best parts, but nothing complicated please, remember i have never built or seen one of these boats up close, except for in passing at RCX this year.
                            here are some of the other parts stephen recommended, please feel free to chime in:
                            Prop
                            Octura x445 or x645 (which one?)
                            Motor Mount
                            Leopard 4074 Mount (ose-80610)
                            http://www.offshoreelectrics.com/pro...prod=ose-80610
                            Servo Mount (ose-80090)
                            http://www.offshoreelectrics.com/pro...prod=ose-80090
                            Rudder
                            Catamaran Strut and Rudder System (ose-80085)
                            http://www.offshoreelectrics.com/pro...prod=ose-80085
                            UBEC
                            which one?
                            and... I have no idea what else I need or what other options i have
                            tia
                              • 7651
                              #1739
                              I got the Thunder Power batteries warmer than they have been.The ABC prop was pulling alot.I had the EagleTree on one battery and got 140 amps peak.Motor and ESC were fine though.I may have to watch my props now that it is warming up around here.If ambient temp is 10 degrees celsius warmer it will have a huge effect.I guess that is why alot of the guys from down south have had less than desireable comments on my prop choices.I can have winter props and summer props,I'm good with that.
                              Did you get the high flow fitting on your cooler and get that sealed OK?
                                • 7651
                                #1740
                                Prop
                                Motor Mount
                                Rudder
                                UBEC
                                which one?
                                tia
                                I would start with a 445.
                                Are you getting a 1515.If so you will need a larger tail ring on that motor mount.You may also need my template for the CF rails on the motor mount.
                                You will only need a cheap UBEC as you will only run up to 5s,right(based on 1515)
                                As far as the servo mount goes,isn't there a nice wood one in there?Oh,and you will need a servo rod and rubber boot.
                                Do you have connectors?
