    • 4338
    #1411
    I don't believe the OP is having an issue with shipping from OSE, they were out of stock at the time, so he looked elsewhere. Pretty sure he ordered from Wohlt.
    • REDLINE1
      • 199
      #1412
      Got my first 447 detounged. Probably not as good as some of the pros on here but it's balanced and it will cut
      • Keagan-Z06
        • Mar 2016
        • 970
        #1413
        Every time I see a set of prepped x447s I gotta ask how da hell do you all get such a nice smooth curve. I'm cheating next time, Dasboata I'm coming!!
        • REDLINE1
          • 199
          #1414
          I rough shaped it w a dremel that has a stone bit in it. Then finished w a file then emery paper file
          • REDLINE1
            • 199
            #1415
            Got 60 this morning. X442 s&b struts at 3mm 2-3s batteries all the way forward. Probably could have got more but I can't seem to get the hull planted good bow wants to bounce. Thought lowering the struts to 3mm w the batteries all the way forward would help but no such luck
            • Team Lucas
              • May 2016
              • 300
              #1416
              Originally posted by REDLINE1 View Post
              [ATTACH=CONFIG]147006[/ATTACH]
              Try reversing prop rotation to outward spin, helped my bounce problem a lot. ( if you do that don't forget to swap flex shafts). You want to keep struts as level as possible, I also have a small air damn that helped a little. What batteries are you using? btw, don't forget to change batteries in GPS ( your running low)
              Zelos 36 stock 68 mph
              • Team Lucas
                • May 2016
                • 300
                #1417
                It is not that hard to do it, its hard to get all 4 blades the exact same lol. I cut one 1st then used modeling clay to imprint the cut blade, baked it hard and used it as a templet for the other 3. I saw a vid on it and it worked out great.
                https://www.youtube.com/watch?v=OtEIhWQtxVo Might want to start it 1 min into it.
                • REDLINE1
                  • 199
                  #1418
                  No haven't tried that. Will do thanks. Running 2 reaction 3s, 50c 5000mah. Gps is recharging as we speak
                  • REDLINE1
                    • 199
                    #1419
                    Originally posted by Team Lucas View Post
                    [ATTACH=CONFIG]147022[/ATTACH]
                    I didn't have any clay so I used masking tape to make a template of the first blade then transferred it to the other three
                    • Team Lucas
                      • May 2016
                      • 300
                      #1420
                      Two 6s forward. Only 4300 mah and 40c, but 3/4 pound liter and easier to adjust CG. Weight ver's power is my thinking. Find out tomorrow at the pond :)
                      • Team Lucas
                        • May 2016
                        • 300
                        #1421
                        don't know why all my pics are upside down, sorry for that
                        • REDLINE1
                          • 199
                          #1422
                          [ATTACH=CONFIG]147023[/ATTACH]
                          Keep us posted
                          • Team Lucas
                            • May 2016
                            • 300
                            #1423
                            Ok just got back after trying out 4300 mah 40c constant 80c burst 2x 6s batteries all the way forward. Today was hard to compare last weeks runs with 4x 3s 5000mah, very windy today, but the boat settled down better and still had speed. Flipped it twice hitting a wicked cross wind, going into turn 1. 1st flip was 66.6 mph, 2nd was at 64.6. no damage, no battery shift
                            • Crazykev
                              • Jun 2016
                              • 44
                              #1424
                              Finally heard from Jeff. My drive cables haven't even shipped yet and won't til at least tuesday. That sucks!!!
                              • Team Lucas
                                • May 2016
                                • 300
                                #1425
                                It does suck:) not to be on Jeff's side, but I been emailing him back/forth since I ordered mine and learned that he has a hard time lately getting the collets. No since sending out shafts if there's no way to use them. I just got mine today, and for a guy to do this on the side and it not be his main income, Wow...he packs them in a tube no carrier can bend/ruin unless they blow it up lol. Very nice shafts, haven't fit them yet but I haven't seen any others post review on them, so I will start fitting them in tonight and try out this sunday
