Originally posted by paulfromtulsa
View Post
From what I know of these "wire drive" you cant just run them in the brass drive tube. They have a bearing dive tube for those, has 4 ball bearings in it. There's no way in my mind that w/o those bearings it wont rub, and when it does rub, it's so thin it will either eat a hole in the tube, or shaft get too thin and break. Zelos has that bend at engine side, how will you stop it from rubbing the top part of the brass tubing at that bend? Granted I don't know much about these other then a guy at my pond is running "wire drive" in a gasser.Zelos 36 stock 68 mph
I bought the OSE upgraded flex shafts and here is what I like to point out. There barley longer and why you can fit a bigger prop is because they have a tiny drive dog. the steal shaft is shorter and that's better, but definitely change the drive dog.saft dirrerence.jpgshaft 2.jpgdrive dogs.jpgZelos 36 stock 68 mph
The wire drive from wohlts is a drop in replacement for the cable. No bearings , just need to change out the collet on the motor. Leave the existing liner in. I put one in my spartin , much smoother than the cable but I did have some water leak when sitting in the bathtub because the wire is smaller than the cable. Ended up making some seals out of cooling tube in each end of the brass tubeOriginally posted by Team Lucas View PostFrom what I know of these "wire drive" you cant just run them in the brass drive tube. They have a bearing dive tube for those, has 4 ball bearings in it. There's no way in my mind that w/o those bearings it wont rub, and when it does rub, it's so thin it will either eat a hole in the tube, or shaft get too thin and break. Zelos has that bend at engine side, how will you stop it from rubbing the top part of the brass tubing at that bend? Granted I don't know much about these other then a guy at my pond is running "wire drive" in a gasser.
I went to that site and it says "coming soon"...and where can I get the collets for them?Originally posted by REDLINE1 View PostThe wire drive from wohlts is a drop in replacement for the cable. No bearings , just need to change out the collet on the motor. Leave the existing liner in. I put one in my spartin , much smoother than the cable but I did have some water leak when sitting in the bathtub because the wire is smaller than the cable. Ended up making some seals out of cooling tube in each end of the brass tubeZelos 36 stock 68 mph
[QUOTE=Team Lucas;673640]I went to that site and it says "coming soon"...and where can I get the collets for them?[/QUOTE
Ya I think he's testing them The one I bought for the spartin came w the collet so I assume he will provide the collets with it
Got the wires drives installed today and they seem pretty smooth. Will get her in the water this week. Also Jeff sells the collet for them just email him
image.jpgimage.jpgimage.jpgimage.jpgWhat do you guys think of this idea to scoop more water into the inlets on the bottom of the hull? They are push rod exit covers I had lying around from my rc plane days. Epoxy them over the stock inlet tubes. Not sure if they would stay on or get ripped off. Or create too much drag
so i decided to do so,ething different so i decided to get the zelos hydro dipped in gold carbon fiber with several coats of clear.it actually turned out really well.plus my properlly sized water jackets are finally done so now the fun begins as it is now time to engineer my build.thanks for looking!
Don't do it.Originally posted by REDLINE1 View Post[ATTACH=CONFIG]146649[/ATTACH][ATTACH=CONFIG]146650[/ATTACH][ATTACH=CONFIG]146649[/ATTACH][ATTACH=CONFIG]146650[/ATTACH]What do you guys think of this idea to scoop more water into the inlets on the bottom of the hull? They are push rod exit covers I had lying around from my rc plane days. Epoxy them over the stock inlet tubes. Not sure if they would stay on or get ripped off. Or create too much drag
The picture below shows all that is needed.
Your's should be sanded flat to reduce the drag.
LarryAttached FilesLast edited by TRUCKPULL; 09-29-2016, 07:01 PM.Past NAMBA- P Mono -1 Mile Race Record holder
So I'm Informed by "Rawsteele" via YouTube that I would have too go through him to get a motor from Jose. Is this correct? Nice motors.Originally posted by baller69 View Postso i decided to do so,ething different so i decided to get the zelos hydro dipped in gold carbon fiber with several coats of clear.it actually turned out really well.plus my properlly sized water jackets are finally done so now the fun begins as it is now time to engineer my build.thanks for looking!
Wow!Originally posted by baller69 View Postso i decided to do so,ething different so i decided to get the zelos hydro dipped in gold carbon fiber with several coats of clear.it actually turned out really well.plus my properlly sized water jackets are finally done so now the fun begins as it is now time to engineer my build.thanks for looking!Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
No! Leave it stock or shape it like truckpull showed you. Btw, I shaved mine at and did them like that it it didn't pick up anything. At all. (Mph wise). In other words it didn't go any faster.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
